Oops!I made a bad mistake!I mislabeled bulkheads 6 and 9!I had to cut down 9 and cut 2 new bulkheads to the correct profile for #9!I had to cut the #9 bulkheads out if plastic because the only thick wood I had was 1/8th plywood that shattered when I tried to cut them out with my coping saw.I will plate them with thin wood after they dry.Not a mistake I wish to repeat!
Hi philo
Wish you the best to your project. Am going to follow you because am planning to start Hermione AL as soon as I finish my current build
Chris
No you have to supply your own paint but thst is normal.Finished decking but ran out of mahogany abd used the white wood in the kit to finish.Used stain to even it out but the mahogany darkened more than expected.I may sand it or use a gray wash to represent weathered wood.
But there are not specified.... for example "red" what kind of red? AL in its webpage gives a table where the colors of Hermione are specified according to "Patone color model".It gives the numbers of that system which ofcourse do not correspond with any known model paints brand i.e. vallejo or revell or humbrol etc. Thats what am bothering you about. The question is how are we going to pick the right colors if there are no specification given in the kit.
Hope am not driving you crazy with my persistance but I think is something we have to find out before buying the paints.
All the best and thank you for your response.
Chris
Thanks philo
In the mean time I spoke with a gentelman -modeller- from AL and he gave me the coresponding colors to the real ship in Vallejo numbers. If you wish I can send you the actuall numbers AL gave me.
Chris
