I am building my first model and painting with paints supplied for the kit which is by Caldercraft. I cannot seem to get the metal dull black paint to uniformly cover the brass. Does anyone have any tips please?
Current build - HM Mortar Convulsion (Caldercraft) - Suspended pending rigging experience
HMS Sharke (Sergal)
On the shelf: HMAV Bounty (Caldercraft), Portsmouth (Mamoli) & HMS Victory (Caldercraft)
See the Metal Blackening posts in this section.  I had a hard time getting paint to stick, I switched to oil base flat enamel with 2 coats. I will shortly be getting into chemical blackening of metals which is the other option for making brass black.
Ken
Edited by BareHook
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
Thanks Ken, I will have a look. Glyn
HMS Sharke (Sergal)
Your fittings may be too smooth.  For paint to stick the surface must have a little tooth.  Try soaking them in some vinegar for a while.  After insing and cleaning try the paint again.
David B
When painting metal always prime first with gesso. The arylic paint loves to stick to gesso.
BFN
Cheers,
Hopeful aka David
“there is wisdom in many voices”
Completed: Sharpie Schooner (Midwest) Posted  to the Gallery
Current: Sultana (MSW)
Current: Phantom (MSW)
Next: Lady Nelson (Amati Victory)
It is better to apply chemical blackening, than paint, for example Blacken It liquid to giving of brass fittings of black color or 20% solution of selenious acid.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Blackening only works on the brass itself, not on soldered joints. However, blackening first and then applying a light coat of black with an airbrush might be a good solution - the second best would be applying the paint with a brush. The blackening gives the brass a 'tooth' as well as being obviously being already black. In any case careful degreasing and not touching the parts with bare hands before either blackening or painting is essential.
