Hey howya goin all, what is the downside of using Minwax wipe on poly water based to compared the oil based one, whats the difference between the two types apart from water based and oil based?   :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
My master carpenter brother-in-law told me there is no problem using Minwax water based poly over Minwax oil based stain, so I used the wipe on satin poly over oil with no problems at all when finishing my hull 3 weeks ago.
Oil based wiping varnishes tend to add "warmth" to the wood.  Water based poly leaves the wood "cold" looking, especially darker wood like cherry and walnut.  I use water based only with very light woods like maple and birch.  It dries crystal clear,  while an oil based finish typically has an amber cast to it.
Hey howya goin Dilbert and Dave, thanks for the info.   :bird-vi:
On 5/14/2017 at 1:04 AM, Julie Mo said:
I would test it first.  Some finishes don't bond well.  Or you could put a coat of wax free shellac in between the coats.
Thanks Julie mate, I didnt explain the question the right way agian.    :bird-vi:
I was looking for something a little like Dave said,
I have edited my original post.
