This is the rebuilt of my build log of the King of the Mississippi.
The pictures should be selfexplanatory, since I will start comments as from the point where I am now with my built.
Regards
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
The stable beams in place. As can be seen, the proportions of the stable bars are now in line with these beams. The original bars were far too big, so I am happy I have redone them.
Regards
John
<br />
<br />
Hi John,after years of absence my ship modeling gene has resurfaced, nearly completed same kit,your decking pattern is superb,very neat work,you gave me some ideas already. keep up the good work, will follow with interest. my first comment on MSW, abit long winded,Ed
Hi Edmay,
Thanks for dropping by. As far as I know there is no cure against the modeling gene other than to surrender.
Regards
John
Edited by john46
<br />
<br />
Finished the components of the paddle-wheel: varnished the blades and shaft, painted the paddle-wheels and rod arms and varnished them as well and finally everything is in place.
Regards,
John
<br />
<br />
Goodmorning Adrieke,
Thanks, it took me some time and efforts since my eyes are not as they used to be fourty years ago. Now start painting the second deck doors and windows. That's a real challenge. Am afraid I have to redo them several times before this job is done.
Regards
John
<br />
<br />
Thanks Sjors, this kind of encouragement keeps spirits up.
John
<br />
<br />
Hi John,
I see you are using acryl paint from V&D?
I always goes to Meyer & Blessing just around the corner of V&D
They have a lot of all kind's of paint.
Sjors
Hi Sjors,
The paint used for the paddle wheels is supplied by Lidl. At the time they had a complete box for about no money.
Dependend on the job I use various kind of acrylics, Revell, Tamiya a.s.o.
Yes I visit Meyer & Blessing as well as Harolds.
John
<br />
<br />
Finished the second deck stack gratings and tinted them with walnut varnish. Having the doors and windows painted, a drop of gold paint on the left side of the doors should depict the doorknob. So can now start planking the state-room.
Regards
John
<br />
<br />
Finished the planking of the stateroom. This was an extensive job to do since I had already placed doors and windows, so had to plank around them. Didnot bother too much about the windowsides, since these will be covered by the windowshutters.
These are the next thing to do. According to the building instructions these shutters (according to the part list they are called portico windows) are added nearly at the end of the build, but I cannot see why I should not do them now. Doing them later will be more complicated.
Regards
John
<br />
<br />
Thanks Wim,
Had a look at your builds, they are all very nice. So I am delighted with your compliment and hope my King will end up acceptable. Anyhow it is great fun to build this Huckleberry Finn paddle steamer.
Regards,
John
<br />
<br />
Thanks Adrieke, but nope, I think you are still ahead of me. You have already prepared a lot of parts. Think that the most time consuming is the scratch build of the doors and windows you intend to do.
<br />
<br />
Hi Rhodri,
You are completely right, thats the way to do it. The paint I used was enamel paint from Revell. Tried acrylic paint but since you have to wipe off the paint before it dries up, it appeared that there rested not enough paint in the carves.
Regards
John
<br />
<br />
Having painted the window shutters. An extensive job, there are 48 shutters in total. This is the end result.
<br />
<br />
Thanks Wim, thanks Sjors
Luckily I found a "winterschilder" so got a great discount on the job :D
Regards
John
<br />
<br />
Thanks Brian,
Donot overestimate, as you will experience with building the Mare, it is just a matter of start a build and do your utmost to arrive at a good result. Nothing special, if you like modeling it is just fun.
Regards
John
<br />
<br />
Finished the first deck stairways. It was not an easy job to me, it took me a week and have redone them several times to have them symmetrical to each other and to have a 180 degrees winding.
Maybe it can be of help to beginner builders to describe the way I at last succeeded:
1. Glued the first curved step to the stairway column at the height of 5 steps
2. Glued the other curved steps with a minimum of overlap
3. Glued one straight step to arrive at a winding of 180 degrees
4. Glued the other 4 straight steps to each other, again with a minimum of overlap and with help of some wood as a frame
5. Glued the short railing to the 4 straight steps and then all together to the stairway column
6. Finished by glueing the long railing and handrails
Have dryfitted the stairways after each and every step to see whether they will fit.
As can be seen, one of the loose end of the long railings was broken, so I decided to cut it of from the other longrailing as well. If I donot like the result when placed the stairs on deck, I will restore them.
Regards
John
Edited by john46
<br />
<br />
Guest
This topic is now closed to further replies.
