Does anyone know the length ranges of an English 4 pdr cannon and a 6 pdr cannon of around 1780?
My Bounty has four four pounders but the kit cannons are 'ok' but I would prefer to get better and though I could scratch them I am just buying better for this model. I like the look of Chuck's but the smaller non-swivel ones there are 6pdrs. Since the bore is not drastically larger from a 4pdr to 6pdr I wondered if the lengths overlapped (or were the same) so I could then get the nicer looking cannon.
In town  so no access to the relevant books.
Thanks for any opinions.
Blomefield pattern 6 pounder 6' 0" long
Armstrong/Frederick pattern 6 pounder 6' 6"
Frederick pattern, 6 pounder 6 ' 6", 4 pounder 5' 6"
(From Caruana, The History of English Sea Ordnance, Volume II)
Take your pick!
thanks druxey. i had a look myself at 4 pdr sizes and Lavery says they were between 5 foot 6 and 6 foot which is at scale 23.8125 mm to 28.75
the smallest syren is 29.76 so is close but I wonder if I could just get the relevant carriage and use the kit cannon.
i used Chuck's guns for my Licorne as 6 and 4 pounders.   I would think you could go either way as far as cannons or carriages.  But you might ping Chuck to get dimensions to double check.
I have ordered some anyway. I only need 4 so the cost is minor and then I can visually check. I may end up using Chuck's in their entirety or just the carriages... Worse comes to the worse and I can always scratch build them. I was surprised how bad the kit gun carriages actually were (the cannon themselves were fine)
