Hi all
Snowy here just wondering the best or nicest way to tie a 2mm block to an eyebolt
Cheers
Edited by Snow
Spelling
    I usually tie small blocks to eye bolts while they are still off the ship, then install the bolt to the ship.  Trying to tie knots thru the confused mass of rigging and fittings that are already in place is much harder than just installing the bolt to its place on the ship! B)
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
3 hours ago, druxey said:
Usually blocks are hooked to eyebolts. This means threading a hook onto the strop and seizing it in before wrapping the strop around the block.
    And don't forget that most hooks were moused to prevent them from coming loose when the lines were slacked off.  See this illustration below taken from Rigging Fore-And-Aft Craft by Lennarth Petersson.100_4657.thumb.JPG.53865b99087282f83418e5271c6f8a45.JPG
Dave
