Having completed HMS Cruiser and HMS Snake I decided I needed a break from Rigging😕 and having seen Jack P's build log I have decided to try the Oseberg. After an initial confusion at finding that the laser cut frames were arranged in a different pattern to the diagram in the plans I have set to it and started the keel.
I have decided to stain the wood dark mahogany and have stained the frame and planks with two initial coats.  I have mahogany veneer to cover exposed plywood edges, but otherwise will be using the wood supplied
Photos to follow
Dave,
Good luck - will follow along - my next build will be a Viking ship. Yes Jack P's is gorgeous indeed.
Regards,
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Attached is the diagram in the Oseberg manual, which I found different from the materials supplied, two separate pieces arranged in a different way, fortunately I soon realised the symmetry of the construction and was easily able to work out the position of each frame.
I gather that I will have to drill the oar holes in the top plank using the plans as a template, any hints on doing this without causing damage would be appreciated!
Sides just about completed, now the decision as to how to work the bow & stern.
I think it will be trial and hopefully not too much error, I intend taking down the layers of ply on the boat itself rather than the scroll work, but the final decision will have to wait until I have completed the removal of the first layer.
  • 4 months later...
  • 3 months later...
