I am getting close to installing the foremast. I was often confused about whether to clue it or leave it loose and let the rigging keep it in place. I know if I glue it, I will break it and be screwed. If I just set it in the mast hole and let the rigging hold it in place, it will twist, and I will be screwed. I came upon another method that I am going to use. It is a product called Quick-Stix remove-able wax. I purchased it on Amazon for $5.00 .My wife has a friend who builds miniature doll houses and uses it all the time. It is a soft wax that sticks to what it is applied too. It holds the item firm in place. If you need to remove it, ok. If you need to tweak it, ok. I feel it will be great on the masts and bowsprit. Just put a little ball of the wax on the bottom of the mast and stick it in place. It will hold them in place, while the rigging is done. If you have an accident, you can remove it. You could use it in many instances while modeling.
Geoff
NRG member #2666
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
 jct, I think you will like it. The price is right. The doll house people use it to mount doll house pictures on the wall andset furniture in place. It is great to mount you masts, and then if you need a tweak, just turn it a bit.
Geoff
NRG member #2666
