Planking...
Regards.
End: Bryg corsair occre, Black Pearl Hachette, Scottish maid artesania, BKA 1125
In build: Vasa deagostini, Dwunastu Apostołów deagostini, Hms FLY amati Novik modelik, spitfire airfix,
Wait for build: hms alert shipyard, orp kujawiak wak, hms Beagle occre, thermopyle revell, few JSC models,
End of the hull planking-definitely
Regards.
studding stern. Based on 1/10 model in Vasa museum and book "the royal warship Vasa".
Regards.
Regards.
studding..
Regards.
Enjoying your blog. The studding work is intense for detailing. I might try to tackle that on my "Vasa" when I start her after my current project which will be a few more months to complete. I assume you just clipped them off level with the planks as you went and then gently sanded them down?
Very unique detailing procedure really adds to the rustic historical look of her, simple but very time consuming; excellent work!
Current build project:
CSS Alabama 1/96
https://modelshipworld.com/topic/20148-css-alabama-by-jonathan11-revell-196-scale-kit-bash-90-historical-accuracy/
Finished build projects 2018:
H.L Hunley 1/24
CSS Arkansas 1/96
If i good understand..
Studding is toothpick and the https://www.modelnet.pl/akcesoria-szkutnicze/gwozdzie-szpilki-oczka/gwozdzie-10mm
First i glue the planks on hull,  initially grinding, and stain. After i sand the toothpick, and stain again. This technic give me satisfiying effect of wood shadows.
If someone is unclear, write!
Good luck!
Regards.
studding....
Regards.
Regards.
studding....
For now everything is going with the plan
Regards.
End
Regards.
Hi Wiktor. I like your planking. You are taking time and when you think it could be better, you are correcting it (eg the stealers at the bow). The planking is hard to get right. It is made easier by double planking but it it still hard. Pictures of the actual ship help immensely. There are lots out there and a few of us have some we can provide as well.
I also agree with you regarding the planking colour and the suggested painting in the Instruction manual. I MUCH prefer to see the stained product which you are using, as it shows the wood grain and the beauty of the timber. It is also much more authentic of the actual ship (as it is now in the museum). I especially like your plank jointing. You have done a great splicing, angled joint job. What are proposing to do regarding nailing? The many nails on the actual ship have a combination of iron and tree nails (and now, replacement nails for conservation), but they are a feature which is an important part of the ship's appearance.
You look as though you have nearly finished the planking and it will be a big relief to have behind you. The result looks great, so congratulations. I will continue to watch your build with interest.
Regards,
Peter G.
Hi. Thanks.
I use the ready OcCre products. It fit good to Vasa model scale. https://www.occre.com/pins-10-mm.html
For the wooden pins i use the toothpick.
Regards.
End of the toothpick studding.
End of the nails studding on one broadside.
So far im though happy from the final effect. But now i would do it a little better.
Regards.
Thnks :)
Regards.
super job on the hull.......the studding really make her looks rustic ;)   glad to see some of your work :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. :)
Regards.
Hi.
End of the studding.
After over halv a year...
Everything went correctly with a my plan.
But... The photos highlight the bad watching error... But they disappear with the tangle of ropes, guns, or paintings.....
By the way, the result was satisfying me....
Next i going to do the deck...
Regards.
Regards.
Front deck...
Regards.
Deck planking.
Caulking done fine black thread. This way need more time than popular method using by beginners-drawing edge of plank by pencil... But for me effect rewards it. Caulking is realy clear.
Work in nose moving forward.
Regards.
Hi after small brake.
Deck planking end. The result satisfied me.
Regards.
deck studding
Regards.
