 I made this lantern from .250 inch dowel turned using a drill, jeweler's file, and X-Acto knife.  The cage is 24 gauge brass wire, the bail is 22 gauge brass wire. I painted before adding the wire and completed the lantern before parting. The real tricky part was cutting the cage wire the correct length to press into the the top and bottom purchase points then used SG to secure. From base to top of bail is .650 inches, with bail collapsed the height is .500 inches.
Beautiful work Keith; and very useful as an added detail for my build.  While my shape/detail may be different I appreciate you sharing the technique.
cheers
Pat
Pat
 Thank you, that means a lot to me and thank you to all for the thumbs up.
  Keith
