G'day
For a beginner is "white glue" the best way to go?  Also, I"m building the AL Viking which has sharp bow/stern, is a Micro Dremel the idea?
David
Answer: "It depends." There are variables, depending on the material and the purpose. Use the forum's "search" feature for openers under "glues" and "adhesives." There's more than anybody could hope for about them in here. You'll probably find an answer that way.
Bob has good advice.   Also, use the search index or the one here:
 and see what other builders have done for a similar model.   Each model has it's challenges and sometimes it's glue related.
