Gidday Harry and a warm welcome from the Land Downunder.
I would suggest you search through the build logs. Here you may find answers to any questions you have. If not you have certainly found a site where the members have a wealth of knowledge and vast expertise. I have not had experience with your kit but I am hopeful you will find some advice here.
I wish you all the best in your build.
Mark.
Mark.
Good morning from a sunny UK mate, thanks for the welcome,,
yes been looking through some of the write-ups, found some very useful information there, looking forward to my build, will keep members updated, thank you again, and have a good’n Mark.
The material that binds wood fibers - lignin - is not water soluble.  It is soluble in anhydrous ammonia, an explosive and dangerous industrial agent.
It is not soluble in household (5%) or 20%  ammonia. These just damage the planking.  Heat will loosen lignin and allow for more bending.
Water on the surface of the wood - when contacted by a dry heat source - becomes steam and penetrates the wood with more efficiency than just dry heat alone.  A microwave and wet paper towel wrapping,   or direct steam  will work.  Soaking in hot water works - but sort of reverses the original seasoning process a bit.  Ideal is to let the bent wood dry in its future conformation.  If you dry in an over bent conformation, try to keep that at a slight amount.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Hiya Jaager, thanks for that, very informative, i will give the soaking a try, the planking is very thin and seems to bend very easy, the thing is, the first three planks have to bend and twist, at the bow and stern, being a Viking ship, as you know are both pointed,,, but you have given me some good ideas now, and forthat I thank you.
regards.
Harry.
If the bend in the thick dimension proves difficult - wood does not readily comply to doing that -  start with a wider plank and spill it to the up curve.
Spill = spoil = waste a lot of wood cutting an "S" shape.  That is how it was really done - mostly.  The database here has planking tutorials the explain all this.
NRG member 50 years
Current:
NMS
Other
Yes mate having a good look at the data base for any help.
Harry
:sign:
