Hi, I have a molded plastic half-hull of my full size sailboat, and would like to paint it to represent the real-life boat which is finished in two colors of Awlgrip. Awlgrip is too expensive and requires too much application skill for my model, so I'm looking for a substitute that will result in a glossy finish. Would you recommend enamel, and if so, which brand? Ideally I would like to mix colors to match the original (I have the rgb codes) and I can use an airbrush.
have you considered a rattle can
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Use a gloss clear coat over the paint used.  Just use a compatible clear coat.  Using same brand clear as the colors is best way to assure compatibility.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
