Hello, friends! MSW member Clare Hess did such a bang-up job of describing this Shipyard kit in the first post of his build log that I took the liberty of copying it to create this review. You can find Clare's build log here -- and knowing his work, this will be a good one to watch!
______________________________________________________________________________________________________________
Earlier this year, I managed to acquire a relatively new kit produced by the Polish card model kit maker Shipyard. The kit is one of two that were released at least a year ago, maybe longer. Both kits represent medieval Cogs from the 1300s.
Unlike other Shipyard kits I've worked on (yes, I only finished one paper ship model kit, but started a couple of them) which were paper kits and required cutting out pre-printed parts, this is a laser-cut card stock kit. Everything is already cut out in this type of kit, and the model requires painting.
The kit I am building the kit listed by Shipyard as the Hanse Kogge - Bremen 1380. It is a 1/72 scale laser-cut kit based on the Bremen Cog. The completed model measures a little over 13" long and about 12.5" high. I decided to go ahead and take on this kit, though I have other projects, as the laser-cut design should make construction much simpler than the paper kits I've worked on. Ages of Sail, which is how I got my kit, sells this kit for about $125.
There is a second Cog kit available called the Wütender Hund. It's a slightly bigger kit, maybe a little more complex, that sells for about $10 more.
If you're interested in buying one, I'd really like to see other build logs! Here's a link to the kits on Ages of Sail: https://www.agesofsail.com/ecommerce/catalogsearch/result/index/?cat=72&q=Kogge
So, taking a look at the contents of the kit...
The laser-cut parts are in a cellophane envelope, individual carboard boxes keep things from knocking around in the main box and contain parts, paints, etc.
The instructions make up a full-color booklet filled with photos. There's very little text, and what there is in multiple languages.
IMG_0209.jpg.81ae4fe03ae2a3da155390f73f213e23.jpgIMG_0212.jpg.aa9112bce494faf1d177cb515f8cefa5.jpgIMG_0213.jpg.9998c8e9d34f50ea784dcc0445828b46.jpg
IMG_0215.jpg.4be5e7f97fd0fa2539ca348e94f87d1b.jpgIMG_0217.jpg.c2f646201baa1cfadded0507abb8e503.jpg
Parts that aren't part of the laser cut sheets are provided in a couple cardboard boxes that include rigging line, laser-cut blocks and deadeye sets, paints, brushes, dowels, metal accessories, etc.
IMG_0235.jpg.dda11865cb8ed8b2d108f395f60e38a6.jpgIMG_0237.jpg.42a83967deb747652e3cc189ea951f65.jpgIMG_0238.jpg.5d2d5068926e1393674b30f2940daea8.jpg
The sail is pre-cut and pre-marked, but will need to be painted.IMG_0208.jpg.3e4122e94efcd3f5296b2ea98a03bc43.jpg
There are several sheets of laser-cut card stock in various thicknesses and finishes. Some of the sheets have a glossy finish. Here are just some of the sheets.
IMG_0227.jpg.018862a43087871b0440c15c51fc9b22.jpgIMG_0229.jpg.cba98d2673a2eae70f9a0c7bc2658305.jpgIMG_0232.jpg.7972fab711b3914be0bf5bc1134a1b6c.jpgIMG_0233.jpg.63d873262cfd9b079f065fb6a9038f2a.jpg
There are a couple sheets of plans included, which mostly cover rigging details.
IMG_0220.thumb.jpg.ec92059a747c09b1062d760b9c437dd7.jpgIMG_0221.thumb.jpg.a6f0518ba271b2b8b7e86571296278c8.jpg
This looks like a very good kit and I'm pretty happy to be able to work on it. Next time, I'll post the start of construction.
Clare
