Hello
I use Google translate so excuse if the translation gets weird.
Here I was going to write about the construction of Billing boats Denmark. I have tried to build several boats before but either I get stuck in some problem or I lose interest.
This time around, I have the goal of just building on whatever happens. I do not have the ambition that it will be something fantastic but just ok.
One thing I have trouble with is bending the 2 mm thick plywood that sits at the top of the sides of the boat. I have already managed to break such a part when I tried to bend it over steaming water. Should it be soaked and if so how long?
So far I have come.
Only the deck in the middle is glued, the rear deck is only fixed with a few screws.
Here is a small problem, the deck goes 3 mm outside the frame. The plywood to be glued is only 2 mm.
Edited by ubjs
Hello ubjs, I pretty new to this site and like you a little bit of a novice building wooden ships. Many different ways of bending planks my way is to use a electric plank bender. I soak them for about 20 mins or so this makes the planks bend easy with the plank bender. For really tight bends i’ll soak them a second time. Good luck with your build and i’m sure your get all the advice your need on here to complete your build. Anyway i shall follow you and offer what advice i can. I’m currently building the USS Constellation i have a build log on here you may like to take a look because i’ve now finishes most of the planking with a few photos that may also help.
Yes, I have a plank bender, I will try it.
Another question, plank the deck or the hull first?
This ships hull shall be painted white, maybe its better to do the deck first?
Looking at your photos I would plank the hull first but it doesn’t really matter. Your need to protect the deck if you plank that first. Did notice that you need to fair your ribs more before you start planking. Fairing the ribs is the most important thing about planking they must run in a smooth curve from bow to stern. I have a link somewhere i’ll post to you on the subject of planking. She looks a long ship so it shouldn’t need much fairing at midships but certainly bow and stern will need fairing better. Anyway i’ll go find that link and post it to you will explain planking better then i can.
Yes, I must fair more.
There is much about Billing boats that not is good but one thing I like is that they have most of their drawings and plans one their website to download. If someone want to follow the build more in detail you could look at the drawing.
One thing is that the foredeck goes a bit over the deck in the middle and will be difficult to work with when you have clued the foredeck.
Hej ubjs, welcome to our world and nice start of Danmark.
You are one of very few building Danmark, so your build log will be an asset for our build log bank.
One of the kits on my shelf waiting to build Danmark. So I am looking forward to follow along with yours.
I see a section build in the background, please let us know more about it and start a build log of it as well.
Respectfully
  • 4 years later...
On 5/8/2020 at 4:43 PM, ubjs said:
Hello
So far I have come.
  • Hei I’ve startet the building of my Danmark for more than 35 years ago, and I have lost a fev parts of my manual.
  • are you able to hjelp me with the color name /numbers used on the ship. Main body, deck and « fittings»
Bending plywood is very difficult, if not impossible, even when you soak the wood and heat bend it! Plywood is glued from several thin layers of wood (laminated) and this prevents it from bending, the piece tends to spring back to former shape.
Instead, you might try to use a solid wood piece, soak it in lukeworm water for a few minutes - half hour and using a soldering iron set to ~ half heat, press it to the wood and try to bend it at the same time, making sure you do not scorch/burn the wood.
You might repeat it several times until you get desired shape.
Good luck,
Thomas
PS: About this fairing of the hull (bulkheads) before planking, I found such a pic, I don't remember where it came from, but it shows the general principle.
Edited by Dziadeczek
Here you could download instructions and plans.
https://www.billingboats.com/index.php/modelboats-footer/79/120/boats/the-expert/P-bb5005-danmark
My build is on hold. :)
I have just taken up Santisima Trinidad, cross section.
Because I always get problem with firewall when trying to upload pictures on this forum I now write my building log on Ships of Scale.
Edited by ubjs
Adding text
