Do any of you brains use any sort of special tool for cleanly driving brass pins into wood? I’ve managed to band at least 10 so far and I’ve given up..
On the bench:  Vanguard Models 1/64 HMS Speedy
On Deck:
Vanguard Models 1/64 Zulu,
Vanguard Models 1/64 Fifie,
Victory Models 1/72 HMS Bellerophon
1 hour ago, marktiedens said:
I usually pre-drill holes for the pins  - slightly smaller than the pin diameter.   Very seldom bend one unless it`s started crooked.
Now why didn’t I think of that. Duhhhhh.  Thanks. It makes sense
On Deck:
This thread may add more insight for this topic:
*https://modelshipworld.com/topic/23377-nail-drivers
Edited by Jaager
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
You can find punches with concave or "dimpled" ends - for leather working. They are usually knurled for a good grip, and the hollow end won't slip off the head of the pins. For really snug fits you can use a small hammer to tap the end of the punch to encourage the pin to enter the wood.
I have inserted very small pins without drilling, but drilling a slightly undersize hole first makes life a lot less frustrating!
Phil
Current build: USS Cape MSI-2
Ernie
If you're using the very fine pins that come with your Speedy kit then a nail driver will definitely not work. I know - I tried! With the softer wood used for first planking I found I could push the pins in if I gripped them with fine needle-nosed pliers. If you need to pin any of the harder second planking, for example the wales, you need a pilot hole as others have recommended.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
No problem, now I'll just grow a couple extra arms and I'll be golden.
On Deck:
