added all the wiring now and put some wooden strips in to easily hoild it al together
one of the legs of a light broke and when i replaced i soldered it in the wrong way . hope i didnt mess up all the lights of that circuit
just abit more sodlering and add the breadboard with resistors to the assembly and its done
will get pictures later today
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
If that job done, you're an accomplished electrician. ;)
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
lol John
dont think so. i was about to forget about it all when i accidently touched the hot part of the soldering iron .
bit more soldering done
had hoped to finish that part today but had to do some after hours maintenace work on my works email servers, luckily i can do
it from home so while i monitor the progress i can be on here ;)
hopefuly tomorrow i l be able to finish and then ad dome sides and a cover to all the wiring and give it a bit of paint (white below / black on top) so that it all blends in
i also think i have figured out how to connect the 3rd deck and steering house
as this whole assembly wil be removable to get to the inside wiring i am thinking of using some thick copper wire i have from another kit that once the assembly is put in place connects up with the lower deck wiring
Nice progress Adrieke, it looks very neat.
If you connect a generator to the paddle wheel, you have a selfpowering lighting device by turning the wheel :D .
John
<br />
<br />
lol Sjors
you know not a bad idea for a future scratchbuild and make it into a rc model :). but beyond my capabilities at the moment
thanks for the confidence Sjors but i know where i am at and compared to most here i stil have a lot to learn
i do feel good about finishing the wiring for the lower 2 decks
testing showed that all 4 circuits are working
now i need to add some sides and a top to cover up the wiring
the top wil be painted black this should make it mostly invisible if looked at through the ventilation windows at the top
i can now concentrate on the build again and maybe assmeble the main stairs
Great Lighting Adrieke, done a fantistic job. When I see those lights coming out of the stateroom I got the feeling : "where's the bar, a double scotch please".
Regards,
John
Sorry, should be a double bourbon. . . .
Edited by john46
<br />
<br />
Adrieke,
Well done. You've booked some wonderful progress on her. Love the lights!!!
Carl
thanks for looking in John and Carl :)
yeah i feel good about it and glad that part is done because it was a bit of a strugle
Edited by Adrieke
not much progress today
started on drilling the holes for the ventilation openings but after 21 my hand was sore so i called it a night
Adrieke,
You'll be at it for a wee bit longer. You don't have a drill standard with electrical drill? That would speed things up considerably, and eases up on your hand ...
Carl
Hi Adrieke,
Nice to meet you also, just like John  :)
The light looks great.
I know what you mean by drilling all those holes.
That's why I gonna buy a drill standard  :)
I have to drill a lot of holes and don't wanna do it by hand….
Hi Carl
no i dont have a drill standard. my workplace is pretty small so no room for  tools.
thank you Sjors and Wim. :)
this weekend has been all about the main stairs
i have been pondering about it and lookign at how others tacled this construction
they always say to cut things in bite size portions and thats what i did
the curved part consist of 8 steps making 180 degrees or 2 times 4 steps making 90 degrees
4 steps seemed doable so i started preparing :
i drilled some holes so that the dowels would be as deep as the point where the curved steps start
from the left over from the sheet they came from i cut 6 small bits
glueing them together to create a platform to rest the curved steps on while the glue dries
at the base i glued a piece of strip against the middle of the dowel to push the first step against
i used a metal angle bracket to measure the 90 degree angle
i formed the platform a bit more so it would fit. all the elements are now ready
the 4 curved steps glued in place
after creating 2 sets of 4 steps i remembered i needed the others to curve the other way so i glued the base on the other side
Edited by Adrieke
continued
glued the first set to the dowel while it was on the base . the second set will easily fit on top using CA
fitted them on to the ship. i previously drilled holes in the deck so that the dowels would fit post-622-0-19387700-1364091873.jpg
the top of the rails need a bit of sanding so they dont look as square
then a bit of stain . bit of fine sanding after will make them lighter
finaly using the stairs themselves and the platform i assmebled the 2 straigth steps
the 2 long curved railings are wrapped around a toothpick holder to curve them
Edited by Adrieke
You did it ! It looks perfect, well done. :champagne:
Regards,
John
<br />
<br />
thanks John and Wim. yes this must be the hardest part on this model
i actualy had more trouble with the straigth steps as each step holds on to the next only a little bit.
so i had several times that a step came loose before i finaly had it done
i have now added both the side railings on one of the stairs. i am going to let it dry over night just to be sure it stays together
i am bending the top of the rails to prepare it for glueing it on.
the other stairs need to long curvy rail to be glued on but waiting for the first one to come out alright first
i had a bit of time left and drilled some more holes and glued the window framing parts on
Adrieke,
You're doing great mate. That's the right way you've tackled the stairs problem. Now they look real good, very sharp indeed. Those holes, well, it's maybe the proper thing to do, every day a few and some other work on the side ... Keep it up!
Carl
Yep, drilling is boring. After having finished the stairs I suppose you will go fast having prepared a lot of stuff already.
Regards,
John
<br />
<br />
hi Carl
yup a few holes a day keeps me going ;)
hi John
i havent have much more prepared except the steering house
also i need to see if i have enough left over wood to scratch build the windows and doors.
my main concern now is making sure that i get the right curve in the ventilation window assembly as the idea is that it wil not be glued on to the 3rd deck for access to the wiring inside.
once i got that right i can finish 3rd deck and steeringhouse
but still lots to do before i get there
Thanks Wim :)
i had a look at your Mississippi and it looks great :)
one of the reasons to show/share what techniques where used so future builders of the same model cna use and improve them.
