Doing the planking job on a scratch made 1/35 scale model of Titanic Lifeboat 15, one of the standard 30ft boats and also the aftmost one stored on starboard side. The boat is not the Artesania Latina one by the way, although I do own it and while I was building the thing years ago, I nearly sent it flying across the room out of utter frustration, the kit still stays unfinished as of today.  I would say that the AL kit is neither accurate nor friendly enough with first timers in wooden kits,let along the fact that clinker planking itself is already way much challenging than the straight forward carvel planking.
     The current lifeboat plans was directly tanken from an expert Titanicist on TRMA, I ditched all the thoughts of using AL parts and completely reengineered the entire hull.  The keel, strakes were all new fashioned.
     This is the second wooden model boat I've worked on, the previous one being the AL kit. I've followed a traditional clinker boat technique to smooth out the plank joints where their ends meet with the false stem and sternpost. That is, having all the plank tips slightly rebated, and all the inward, lower area of planks bevelled(see last two pics).  After I've finished all the planks on the hull including the gunwale, the plank joints at both ends will receive a final sanding to ensure that they lined up neatly in a straight line. 08265AA7-2975-4B33-887B-74C6C59D8E65.thumb.jpeg.88f991847f23c23584d39f6ae25831ce.jpeg00609A46-629A-4A93-A8E1-B050A9A09736.thumb.jpeg.0de509cedcb4102490aa9d1ffb5a118e.jpeg941FBB47-AB9D-49AD-BF95-B30394E3A969.thumb.jpeg.af1d2ed601845e0fa40519520a29800b.jpegF107A6FC-FB43-48FD-89C9-CD7CC1CDEE5D.thumb.jpeg.2aa265d3250dcf97c3b69c4dfacafa4c.jpeg75143D59-E228-4B31-9E9A-D30E59532C16.thumb.jpeg.be37410112f82eb4a066da59652db3cd.jpeg
Hull planking on Boat 15 finally finishes. Next job would be fitting the rubbing strakes and capping to the gunwale. Also some filling and trimming job is needed on the stempost and breasthook(shape needs to be corrected).
     Some water decals for the boat plaques arrived today. The original photo eched parts supplied in the Artesania Latina kit is placed bellow it for comparison. One could easily notice that the AL plaques are all hopelessly overscaled.
2087924A-B4FE-494C-87FC-973E0E24A5CC.thumb.jpeg.a66b2200a2b8f566c6a07c313255cbe3.jpegCC19B8D4-A525-489C-A5D0-BAF157BEE044.thumb.jpeg.c19102fd9340771c4599d23900057386.jpeg56E828D5-062B-4C07-86D3-CD0A87074F97.thumb.jpeg.549da1f8a38cfd5505b403dd728226b4.jpeg22BF9798-67DA-4A58-9416-47A27EE02DDB.thumb.jpeg.f6f3d6a0d4a1374e47441325d2b2caa1.jpeg
Edited by USS CYCLOPS
Very nice planking job!
From your forum “handle” I can’t tell where you are located but the small craft branch of the (British) National Maritime Museum has built a full sized replica of one of these boats.  I visited the museum in 2018.  Until you have seen one of these it is hard to imagine just how massive that they were.  In many sea stories the Captain orders “Man the Lifeboats” and it magically happens.  This completely ignores the difficulty of handling a large, very heavy object on a rolling, pitching or sloping deck in often cold and wet weather.  After seeing the boat, I came away thinking that the Titanic crew must have been well trained to have launched the boats before she sank.  They were also fortunate that the sea was calm.
Roger
Impressive clinker job, very realistic.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
     Just finished fitting the true stempost. Time for filling cracks and joints.
     Some additional parts also arrived. Among them were over a dozen 1/48 scale brass belaying pins, these are ideal substitudes for the thole pins(rowlocks) and will be fitted to the gunwale capping.
     It has been quite an excruciating job to build the hull,so I've been thinking of making some boat's provisions for a change, starting tomorrow. I shall start on the biscuit tank .730DAAA5-B371-4AA5-987D-AFBD8525F299.thumb.jpeg.1af4c03d84e975768c5eb84222135f09.jpegF237D61D-061F-46E2-B084-C95B2628742A.thumb.jpeg.8197f168187329cbd4a26665d5351bfc.jpeg8E83AF55-A0C6-405B-A6C6-D1FE933DADC9.thumb.jpeg.70468daf1a7b615fb3444502af5522d5.jpeg3167F10C-3650-46E3-8792-F4BB1F54949D.thumb.jpeg.dfd05f040dbedf4389dd86a4637dd337.jpegF13E7BAB-69AE-41EA-95C3-1A87B36DECDE.thumb.jpeg.697c445f69a61dc3b6996290b584215d.jpeg56A98830-7CFB-455C-B1CF-94CDCEAFDD05.thumb.jpeg.be47b6b22bda8ec0a4e5372723ec2d29.jpeg
Roger
Thanks Roger for your kind word, as for the full size replica,I would assume that you are referring to the one in National Maritime Museum Cornwall. I havent seen this particular boat in person other than a bunch of online photos taken by tourists. However, I was told that the Museum's boat shop and I were indeed using the very same plan, provided by the very same Titanicist: Robert Read, whom I've mentioned earlier. That had relieved me of much effort in attaining a reliable source of plan.
Yes,I'd definitely second your opinion that the Titanic crew did an excellent job in lowering and manning the boats, and I think a considerable amount of credit should go to those officers overseeing the launching procedure. It is their duty to make sure the weight of the occupants were always distributed evenly from port to starboard during embarking, and giving commands to seamen manning the falls so as to keep the boat even from fore and aft during its entire way down to the sea in an almost pitch dark condition. It's a miracle that they eventually pulled it off. Any mishaps during these would resulted into catastrophic events(spilling boat passengers into the sea,etc)
On 10/5/2021 at 11:37 PM, G.L. said:
Very nice planking job, Cyclops. You are building just the kind of model that I like. I sign in to follow.
Thanks for the following. I shall keep the logs updated as frequently as possible.
Yes, the boat is located at the Cornwall branch of the museum.  I was able to talk to the boatbuilder there as I was curious about the drawings that they used.  They were unable to find any drawings specific to the Titanic’s boats.  Instead, they used drawings published in a technical paper.  He made me copies of the drawings.
In many cases, lifeboats were considered “outfit” by the shipyards and vessel owners so were bought from specialized suppliers.  This makes information hard to track down.
Roger
Roger
Yes,it's definitely difficult to aquire plans for a quite generic thing like a lifeboat on a specific vessel. Shipwrights at the time all built their lifeboats using a quite similar(if not identical)set of methods and plans, these well tested and practised ways of boatbuilding have already been passed down for generations of boatbuilders with minor or no innovations.  For a large shipyard like Harland & Wolff, the techniques and procedures of building a wooden lifeboat would be so handy and well established to them, to the point that their boat shop could assemble one right away by using stock parts without any plan ever being needed to draw up. Hence the likely reason why no detailed plans about the boats have ever been found among Harland & Wolff files. (although some shipyards did outsourced their boats to dedicated lifeboat companies, but in the case of Titanic, her lifeboats were still built in the shipyard's own boat shop).
