This is my first time logging a build. I bought an model of the Constitution on-line at an auction for $60.00 minus shipping. My whole thought was to build the Constitution at a point of one of her famous battles during the war of 1812. When I got the box and opened it much to my horror that once more Revell took some liberties' with it mold process. There is some major differences of their idea of what the Constitution looked like during the war and what the Anatomy of the ship USS Constitution puts out. I will not give up the ship to a few errors but will push through them and show you what I have done to correct them as well as from time to time ask for advice.
Welcome to the forum! I hope you'll keep this updated, I'm curious to see how you go about improvements.
I finally started to get building. I wanted the windows to reflect the correct windows which I found both in the paintings and the book of the Anatomy of the USS Constitution. I drew up the pattern of the windows to fit in the place of the space. I carefully drilled out the center then trimmed away the rest. It meant that I had to cut the old window out. I had to place each window in place to fit, as well as making the center post. Yes there is more clean up needed but wanted to show how I am trying to make this plastic model to reflect it's time period of the War of 1812. Next I will try to work on the correct decorations that surround the windows. Hey take it easy on me for its been over 30 years since I got back into modeling once more.
Hey please excuse me for large pics. Well all you have seen me doing is by x-acto knife, pencil, and guess work. I would transfer my pattern from paper to plastic. Then I would drill out the holes before I would carefully cut the holes into squares. Using needle files I would shape my cuttings down. The picture I am posting is a prime example of my process. I have been trying to add the window trim around the window from what I saw that the ship had on it during the War of 1812. I am far from done for I need to finish cleaning everything up before moving on to the next modification. Yes I have seen others who do this work cleaner and better but they are using a lot of the state of the art tools. I am just using a knife, needle files, steel ruler, a good light, and my own two hands. Once I am finished with this I will be moving onto making the Main Brace spreader and the Main Course sheet fairlead.
You can fix this, if you'd like. When you add your picture in the reply window, simply double-click on it to bring up our on-board resizing tool. Just make sure to check that the box for maintaining current proportions is marked -- I often forget that bit.
Here I knew that it had to be cleaned up if I wanted to properly rig the guns, as well as to do the deck that I would have to remove all the nobs.722052436_ModelReworked.thumb.JPG.8815d9f2368127e4c69cd39ce2ef81ae.JPG
I had cleaned off everything off of one side and placed it beside each other to show the rework of the inside.
In the past when assembling large ship models it would buckle due to a weak seam down the middle. So now I add a strip of plastic to basically weld the two halves together to prevent separation and buckling.
I have read on how everyone did their way of applying copper sheathing to their ship bottoms I had came up with my own way.
When compared by size and color to coppering a ship I found this to be close.
Here I marked out the size then scribed out my line using me x-acto knife. Taking a nail used for hanging small pictures I cut the tip off. After removing the tip I rounded the edge keeping the bottom flat. Holding it with a small needlenose plyers I tapped the top of the nail with a hammer. It does make the small dents that would look like it was nailed with human hands. The only problem is that the sheet would curl while being worked which made it hard to make my marks. I finally ended up tapping the metal flat as I work it to keep the shape and be able to work it.2068662809_Copperplates.thumb.JPG.187791d51a2c544bbf732918e12fe5ff.JPG
I would turn it over and tap it flat on a hard surface pushing the reverse dents back up and this is the finish product. Now this is time consuming plus as thin this metal is it can be cut with a simple pair of scissors.
  • 5 weeks later...
Stern
Here is the new stern reworked. I used the model made for Capt Hull by his crew. I researched and found two paintings to back up this stern design. I plan to closely model my Constitution to the time frame which when Capt. Hull commanded the ship. Revell's model had most of the details correct but was off on the window's, name on the back, the opening for the rudder and the two gun ports. There was never an oval opening running up and down on the Constitution at any time. There was an oval opening running sideways that stayed that way till after the war. Then the rudder opening became a circle for the rudder. The gun ports were originally windows till the Quasi war which they were turned into gun ports. The name on the ship had numerous styles during it's early years.
Anchor holes
The Revell model originally had oval openings going out sideways which was never used. I drilled out the holes to reflect the opening in a circular pattern going up at a 45 degree angle which allows the anchor to freely drop when used.
