this is the first time that I have attempted plank on frame build, usualy I carve the hull shape from a block then fit keel and planking, then carve as much as I can from inside until I can see a light through, this project has taught me a lot,
first I think I have the pics in the wrong order but here goes first I cut out each frame using a fret saw the where the slots were on the kit I drilled a small hole at each end and cut it with "ya guesed it a jigsaw"
I cut out the keel and false keel glued it up then started fitting the frames using the jig shown it makes the job much easier,
then came the planking well I dont need to say much about that there are enough articles on planking out there, next the fitting out the inside some bits are quite fidjety for my sausages but I manage,
I made the mast and other spars from beech bbq sticks run them in my dremmel to get the taper, I drilled a hole in a scrap of wood held it in the vice and run the dremmel then used a sharp knife to take of the thickest and finished with a few different grades of wet and dry paper,
I think I will make another one now but using english boxwood and holly if I can get it milled, thing is we need a new bandsaw blade its been well used! not much good for any fine work also the thicknesser will need a touch up on the oil stone,
aint winter a bitch!!!!!!!!!
Very nicely done!  What plans did you use for your build?
BTW, I spent a winter up in Thurso, Scotland back in the 70's.  Not many daylight hours way up there in winter!
Cheers,
Robert
Current Build: HMS Mars
Ian? I like the model and am looking forward to seeing the one in Boxwood.
Michael
