 Anna, welcome to MSW. Please see the following, hopefully it helps.
It is a table saw.  It works the same way as an 8" or 10" saw.  For functional use and safety skills, an instruction manual for table saws in general is pretty important to read.   In general, with the smaller modeler's scale saws, the damage that it can do to human parts going where they should not is less, but you still do not want it.
As for the saw itself,  I do not know if the company itself is in business.  Even if you can get an illustrated parts list (IPL) it may not be of value if there is no manufacturer to supply them by a parts number.   I would guess that any parts subject to wear can be had from tool parts vendors.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
There wasn't a user manual when Preac was in business.  If I remember correctly there was a single sheet of information.
I agree that a book on table saw use is good regardless of the size saw you have.  The Preac saw motor is under powered for hard use.  There is a motor upgrade available for $100 that provides every thing one needs to upgrade to the bigger motor.  I purchased it and it is good quality and overcomes the power issue.  However nothing can fix the maximum cut of 1/4 inch.  It has it's uses and I will never part with my Preac even though I have two Byrnes saws.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
