Hello All,
I am building the Occre Santisma, getting to plank the hull, I am watching several videos and everyone is either using Cobbler Glue or supper glue for planking the hull.
Can we use White glue for planking a hull? I am terrified of using CA or super glue as they run all over and also dry too quickly giving you no time for adjustments and also no mistake should be made! I know using white glue will take longer and need a lot of clamping technique, but like the fact you have some time.
Also, any difference in general between super glue and Cobbler/Contact glue? Instructions say use Cobbler glue not super glue, I am not sure if they are the same indeed.
Thanks a lot for your help, in advance.
You can use white glue (Elmer's) or Titebond for wood. I wouldn't use contact cement - messy and smelly! CA glue sparingly, only in places where you cannot hold pieces in your hands and wait until wood glue dries.
I only use CA glue in areas like the bow and stern where the wood tends to have to much spring in it. And even then as little as I possibly can.
For gluing the planks to the bulkheads I personaly use Aliphactic wood glue. I find this gives a stronger bond than normal wood glue.
Paul
In Work: HMS Hood
Finished: -queen-mary-2
Finished: rms-titanic-1912
Finished: king-of-the-Mississippi
Finished: Sanson
Hi Paul,   There should be little to no spring in the planks if they have been spiled or otherwise shaped as in the planking article here at SW by David Antscherl or the four part video by Chuck Passaro.  It takes a little practice but the results are fantastic.
Allan
I would only use cobbler glue/contact cement for a second layer of hull material.  Several Occre kits are designed this way and I been successful using contact cement for the second layer.  I think the Santisma model only has a single layer of planks on the hull.  I definitely would not use contact cement if that is the case.   I think the choice of glue is influenced by factors such as how close of a final fit are you getting on your planks prior to installation.  If you can get the planks close to the final shape, I would use CA and glue 2 - 3 bulkheads at a time working from bow towards the stern.  If you are not getting the shape close and have to nail or clamp the planks I would use wood glue, so you have a little more time to get the nails or clamps in place.
Cobbler glue/contact cement is deferent than CA/super glue.   Contact cement is usually applied to both pieces being connected, you wait about ten minutes, then press the pieces together.  the pressure creates a bond that is difficult to pull apart as soon as you apply the pressure.  It works great when you have large surface areas to apply the clue to.  Not sure it would work well for applying planks to bulkheads with limited surface area.
