Hi all,
Does anyone have info or instructions on making model barrels from individual staves, made from glued-up wedges of wood?
I recall seeing a tutorial on a scale model horse-drawn wagon forum (now defunct) many years ago.  I'm sure it was using a calculation to divide a circle into the required number of staves, then working out the angle to rip these on a mini tablesaw.  They were then glued up and turned on a lathe.  Making the barrel shape naturally gave the 'staves' a narrow top and bottom.  Looked quite convincing, and I'd like to try this vs the laminated staves on a form.
I plan to try and work it out myself, but maths isn't my strong point so wondered if anyone had tried this or knew of a tutorial?  A search here and on google didn't turn up anything.  Will share if I work it out!
Second, maybe easier question - what's best for the iron hoops?  Given the shape, I imagine brass  would be hard to get the flare(?) to lie flat.  Perhaps black lining tape or similar?  Open to ideas 🙂
Thanks,
Darren
Current Projects:
1/72 St Roch by Billings (modified/detailed)
1/72 Flower Class Corvette by Matchbox/Revell (detailed)
Choosing and researching the next cross-section to build!
Projects Awaiting Start:
Various cross-section kits - Victory, Endeavour, Sta. Trinidad, Granado
Cross-section scratch-builds - Bounty, Pandora, Beagle, Vanguard
1/24 Armed Longboat & English Pinnace (Model Shipways)
Paper?
I did a Google search just now for barrel making plans and a lot came up.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Hello TK1
For my model of the Bluenose, these are the barrels I made.
I used a Byrnes table saw and tilt table to cut 6 strips.  The material was 24" X 4" X 1/4"  I set the tilt table to 9 degrees and cut the strips. I ran the wood through the saw and cut 1 side of the barrel stave then I turned the wood over and advanced the saw fence 3/32" then cut the other side of the barrel stave.   After I cut the 6 strips I used a black magic marker to color one side of each strip.  Then I cut the strips into manageable 6" lengths and glued groups of 5 strips together.  After the glue was set I glued 4 of the groups together to make 1 cylinder.  I then used my lathe to shape the barrels, and cut the ends of the barrel to install a top and bottom.  For the barrel hoops I used copper tape which I cut to 1/16"widths, and then liver of sulfur to blacken the copper bands.
MikeR
40 minutes ago, MikeR said:
The barrels and hoops pictured above were made out of dogwood.
This is a new one for me.   Is the wood in the photo stained or is that the natural color?   Any other applications for dogwood that you would recommend?
Thanks!
Allan
Allan
Several years ago 90% of the dogwood trees in my area died off.  I cut down several trees in my yard and I have been using the wood for my models.  It is a hardwood that cuts and sands and keeps sharp angles very nicely. It turns great in a lathe also.   The color of the barrel is off do to the lighting.  The bluenose deck above is the color of the dogwood.
MikeR
On 7/29/2023 at 2:41 AM, MikeR said:
Hello TK1
MikeR
Thanks Mike, that's the sort of thing I was after.  Your barrels look excellent so will try your method out.
Cheers,
Darren
Current Projects:
