How do you fix/hide/address glue marks from wood glue or CA glue when planking decks or hull? Or any other part of the ship. I do woodworking and I find that it can be very difficult to eliminate glue marks, especially from CA. They become even more visible when finish is applied.
I don't use CA but for PVA wipe away excess wet glue with a wet paper towel and scraper to minimize any residual glue that remains. If some remains and dries, which will happen, place a paper towel or rag that is soaked with alcohol, acetone, or vinegar on the glue for a few minutes, then scrape clean.
Allan
Edited by allanyed
CA is nasty and toxic.  Its speed is handy, but not necessary.   Life would probably be simpler of you eschew it altogether.
Between PVA and two part epoxy most all our needs are covered.  Heat activated PVA can replace the instant bond in the few instances where that is absolutely necessary.
StewMac has a premixed Fish glue that might be fun to explore.
There are fads of silicon based dry lubricants for belt sanders and bandsaw blades that should be banned from your shop - bullseye in a clear finish.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Hi, as said PVA can be wiped up CA stains wood, I am a wood turn and i read that if you shellac an area let it dry CA won't stain the shellacked area, it works, use zizzner seal coat the bllseye has wax in it, that don't matter if the area is not going to be painted or stained
You are correct. I've read the same thing. However, being the cheapskate I am, I've always used Zinsser Clear Shellac (containing some natural waxes) because it's s two-thirds the price of Zinsser Seal Coat which is their dewaxed shellac. Ten bucks a quart is a fairly big difference. I've never noticed any problem with waxed shellac at all, even with acrylic paints. I don't use a lot of acrylic paint though and stick to enamels and artists' oils for brush and spray painting. Maybe I've just been lucky. Who knows?
