4 minutes ago, Jack-in-the-Blue said:
the one thing that every viewer of a model asks
Just say 'several lifetimes, but it seemed to go faster than that'.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Well, if I can pull this off the guns will have functioning carriages.
Craig.
Now, I know you really are crazy.
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
Getting there, getting there.
Craig.
It's all in the username. 😁
Good luck with it. Those carronades are tiny!
I have decided to tackle my minute blobs of difficulty by 'forgetting' to fit them. Perhaps they were all in for their annual de-coke and oil change at the instant in history that I am 'faithfully reproducing'. 🤣
Quimp
The concept works, but back to planking for now.
Craig.
Did you turn the barrel ?
How is your planking going?
Tim
Current Builds :
No, they were supplied. But they're only 4 pounder pop guns.
Slowly, about a third of the way through the first layer.
Craig.
17 minutes ago, iMustBeCrazy said:
Slowly
Slow but sure is the best way, so I am told.... I still tend to go at it too fast.
Looks really good.
What woods came with the kit?
Tim
Edited by oakheart
Current Builds :
1st planking is Ramin, softish but doesn't bend well.
2nd is Mahogany or more likely Sapelli. It doesn't look too much like the Mahogany I know.
I don't know many 'exotic' woods.
On the other hand I finally bought some Huon Pine which will be reserved for models. :)
Craig.
I will follow your great build log to gain some motivation. I started the kit maybe 25 years ago and knew next to nothing about wooden ship modeling. I managed the first planking and since then the Le Renard is a shelf queen. Last year, I reentered the hobby and built the Vanguard Duchess of Kingston as my first 'serious' build and finished all the woodwork, hull and masts and try to find the courage for rigging right now.
The Renard will be finished, if possible at a later stage. I visited the replica about 20years ago and that should be motivation enough.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
Welcome Rob, there are two other build logs here for the early version and they both started very slowly. The instructions are pretty poor if you're trying to do a serious build but we'll get there somehow.
As mentioned earlier I do intend to fit the bulwarks prior to finishing the first planking as I'm not an octopus. I'll also fit the keel before starting the second planking so that it all 'blends' nicely.
Craig.
My reserved wood is Alaskan yellow Cedar, which I am using on the cutter Speedy to get used to it, at this moment I have a love/hate relationship with it.
It bends well, cuts well, but is really soft and dents very easily.
I have never used Huon Pine, what's it like?
Tim
Current Builds :
15 minutes ago, oakheart said:
what's it like
Tough question. Expensive-ish. Very fine grain, often highly figured ,sometimes dead straight (like mine), growth rate can be < 1mm per year, often half that. Very long lived.
Can no longer be felled, only salvaged. Very smooth finish, polishes to a high sheen without any need for oils or varnishes. Fades to a soft buttery yellow.
https://www.australianwoodwork.com.au/blogs/news/what-is-so-special-about-huon-pine
https://www.tasmanianspecialtimbers.com.au/special-huon-pine-slabs-for-sale/
Craig.
Somehow with my approach 25 years ago, the fit of the bulwark looks decent. I cant remember the building sequence, but given my non existent experience at the time and also lack of internet resources, because there was no internet then :D, I guess, I followed the manual.
It looks like this, hope that helps (yes, it's not up to even my standards today).
Cheers Rob
The bones are still there and everything but the deck gets covered up anyway ;)
Craig.
And so we come to a rather delicate subject, one not much talked about in polite society since the advent of indoor plumbing. The backside!
So she has an issue with her backside :( It seems to be a genetic flaw common to her sisters but never discussed.
Her transom is wrong! It's wrong and it can't work. It will have to be bodged, fettling isn't enough :(
img_0420c2.jpg.d888f44b1fe5a672004ecd19fb530978.jpgIMGP1018as.JPG.1b6151e007e8f159dbb7143626cb16dd.JPG
Craig.
Hi Craig
While searching for information on cutters, I found these.
some good photos of the replica
nice rigging and replica build
tim
Current Builds :
Thanks Tim, I've seen the second but not the first.
Craig.
