For cutting of laths of a secondary covering in width 3-5 mm and thickness of 0,5-0,6 mm (wood - a pear, padauk, ebone) I have made "minifactory" for cutting and calibration of the laths, consisting of a circular saw (on the basis of FBS 12E) with the device for exact installation of width of a cut off lath, and also a surface gauge (on the basis of MICROMOT 50E) for calibration of laths on width (including in a package till 10-12 pieces).
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation.
Mill PROXXON with a transitive washer for installation on a shaft in diameter of 6 mm and a cartridge 6мм, altered for installation on FBS and Micromot.
Best regards,
Garward
Great set-up Garward, I like the side by side combination of the machines. Please inform me for the disc saw mandrel,  it is a proxxon part? If it is not where i can get one?
Regards,
Gregory
Gregory Kamtsikoudis
Hi, Gregory, thanks for the comment! I use the disk saw Proxxon with a diameter of 50 mm, but it is possible to use and other disks suitable by the sizes.
Best regards,
Garward
Hi, David, thanks for an assessment!
Best regards,
Garward
Garward
That's putting the mind to work. I like the saw guide and the thickness sander. It has given be even more ideas on how to improve my tools. Thanks
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Garward
Thanks for the comment, I am glad that you liked this "factory"  :)
Best regards,
Garward
  • 2 months later...
Very Interesting.. Thanks for bringing this up again.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Later 42rocker
Thanks for the comment!
Best regards,
Garward
