Santos Dumont 14 bis (1906) by Greg Davis - FINISHED - Model Airways - 1:16 scale
On 10/2/2024 at 3:46 PM, Papa said:
Working on the engine. I question whether the real 14 Bis could have supported the Antoinette engine with the flimsy bracket arrangement modeled in the kit.  Mine couldn’t support the model engine for sure.   I had to glue the kit engine to the firewall and put in the brackets after the glue had dried.  Also, using the plan’s placement for engine mounts I found that the drive shaft would not line up with the propeller.  It took a lot of fiddling to get everything lined up and I think the engine is still a tad crooked.
This is not a high resolution photo - however, it seems to show a engine mounting arrangement very similar to the one in the kit.
I had to rebuild this portion of the model at least once and also made a few adjustments to get everything lined up.
I'm not sure if it is true, but I get the feeling that Model Expo is not going to keep this available too long into the future. Recently, they had discounted it to about $55 in one of their sales.
I do like the effect that you are achieving with the tissue covering!
Thanks.   This photo also shows the wing covered closer to the nacelle than the illustration in the instructions. I will have to add more tissue.  I do think there are more engine supports in the photo than the kit provides.  Watch this space for the finished photo of my bis.  Coming soon!
On 6/6/2024 at 10:40 AM, Landlubber Mike said:
Fantastic job!  Really well done.  Seems very fragile, so hanging from the ceiling is a good idea.
Thank you.   It is very fragile.  Joints were popping until the very end.
I will say this about the build.
Gerald Wingrove, in every single one of his books, points out and emphasizes that "YOU SHOULD NOT TRY TO USE THE ORIGINAL MATERIAL TO SIMULATE THE ORIGINAL MATERIAL ON A SCALE BASIS. IT DOESN'T WORK."
For my aircraft, I am going to use steam-bent wood. It will be covered, so this should not be obvious. I am not going to use ANY bamboo if I can avoid it. It doesn't glue well, it returns to it's original shape as time passes, and even with steam bending, it is nearly impossible to form. On most of the original early aircraft I have been lucky enough to get access to, the bamboo parts are typically straight, such as supports for the tail surfaces or to link separate sections together.
  • 5 months later...
This is an excellent build. My own work on this kit is seriously lacking. I am hoping for some help. Everything I have been looking at, including your posts, are not showing how the wing was rigged. I have been studying the instruction manual until I have a headache. I am still not seeing the pattern the support wires are supposed to have. I think I see the hardware/location you used but I would be guessing for most of it. Thank you again for posting your excellent work.
  • 2 months later...
  • 2 months later...
On 7/15/2025 at 4:28 PM, jac harnett said:
Hello
Please tell me what adhesive did you use on the cast parts? I did do a hot soap and water wash. I have tries JB weld fast and slow, epoxy 5 and 45min as well as standard CA. Hothing has held for me.
I'm sorry to have been so slow to respond - I used medium CA to glue the engine castings together. Fresh CA worked well for me, but I've found that if the CA is old it is iffy in terms of the adhesion you may get. In a number of places I did need to file the castings so that the joint locations were tight to one another.
Yes, roughing up the surfaces of smooth parts, such as plastic, metal and resin, helps the CA grip better. Removing paints and oils help, too.
Ken
Started: MS Bounty Longboat,
