Looks great, it could be the perspective in the photo, but it looks like your bowsprit isn’t straight. I think that it should be parallel to the centreline of the hull and roughly in line with the boom.
Photo from my very dusty Zulu below.
Dan
Current Build: Sherbourne (Vanguard Models, 1:64)
Previous Builds (All Vanguard Models 1:64):
Fishing Boats: Fifie, Nisha, ZuluSaucy JackErycinaRanger
Warships (and Yacht): HMS AlertGrecianHM Gun Brig Adder, Duchess of Kingston Yacht
Waiting to be Built: Speedy (Vanguard Models, 1:64)
The sails arrived this morning ad I started tapering the masts as per the plans. I started with the main mast which was square walnut. I was using the mast ring piece to determine if I had got it narrow enough. Some how in the process I lost the mast ring piece.
I searched for two hours and did not find it. So I decided I would try and make a replacement. I got the smallest washers I could find. I had to drill the center of the larger washer out to get it to match the size in the plans. I clamped the washer in a vice grip, then put the vice grip in my wood vice to keep it secure. I will need to paint it black but it will work. not as elegant as the brass mast ring but it will perform the same function. Now back to tapering.
Very nice, I would not fear the rigging by looking at your attention to details.  Plus I hear that  Vanguard Models have the best plans and instructions, and if you get stuck  you got a direct link here to all the help you'll  ever need.   All 45,700 and some of us lol.
Good luck on your journey.   :cheers:
Bob M.
                   WASA
                   USRC Harriet Lane
Thanks, the boat builders here are awesome. I read it every day. Without their experience, expertise and guidance, I would have quit long ago.
