US Revenue Cutter 1815 by Jsk - Seahorse - 1/72 - CARD
Good job!
I tie the thimbles with thread or rope around them, but before seizing, I secure the thread around the thimble with a minimal amount of CA glue, applied with the tip of the needle.
As for parrals, I think these beads are called "trucks", at least that's how I read Modefeld's drawings.
("Historic Ship Models" by W. Modfeld)
Boom and gaff probably definitely had these "beads". In the case of yards, it could be an ordinary truss pendant (i.e. just a rope).
("The Global Schooner" by K. H. Marquardt)
The suggestion to use wire insulation is simply an imitation of these beads, as they are so small that making them by hand without precise tools may be very difficult.
Best wishes
Tomek
Link to comment
Share on other sites
Thanks, Tomek. So the trucks are for the parrels. That makes life easier! I don't have any wire to strip the insulation from so I was going to cut sections from a CA glue applicator tip. I think I could make it work but now I know I don't have to.
Link to comment
After working on the boom and gaffs I worked on the sails. I used a watered down acrylic paint (about 50/50) of a 'sandstone' color to color the white fabric. I hung the fabric like so much laundry on a line and let it dry for a good 24 hours. The fabric had a nice stiffness to it after the paint treatment. Since the sails are printed on one side only I used a thin lead mechanical pencil to draw the seams on the reverse side and then applied a thinned coat of watered down white glue to seal them. (I've happily used Aleene's Tacky glue for the entire project.)  I simply used an knife to cut the sails apart and glued thin strips of the same painted fabric for the tablings and reefing bands. I've not yet glued on the bolt ropes but decided to try the reefing points first.
So... were there standard lengths for the reef lines? And what's the best way to tame them?
The painted fabric:
I used a pin and some cork backing to open the reefing points:
Went away to Lewes, Delaware, for the weekend searching for some inspiration. Found some looking north:
Found some more looking south:
Returned home and added unruly reef lines to the fore sail:
Edited by Jsk
Link to comment
4 minutes ago, Jsk said:
unruly reef lines
You probably know this already, but you can tack the ends of the reef points down with a spot of Aleene's. They should hang straight down, perpendicular to the waterline.
Your Delaware beach looks much the same as a South Carolina beach. Here's one along California's Lost Coast, near where I grew up:
california-coast-humboldt-county-trail-v0-t7rXreRzmYR-CYIey0CKv3drqGkSjxY0yfCFBXpevFY.thumb.webp.cb912c101b4910e8848f2f4cf2ac159e.webp
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Salmson 2
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
