Is it a bad idea to use for the bow filler blocks at the bow/stern on my first build, the Swift? It's an old kit & the triangles they provide seem a little small. I glued in the balsa for the bow but am wondering if I could have problems with the planking coming loose at those areas due to the balsa being so weak.
Thanks,
Jason
A way to make the glue hold better is,  after carving and sanding, puncture many holes in the balsa surface to allow the glue to grip better. Picture many tiny fingers holding on to the  Balsa.  BILL
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
How about a block of basswood?
Okay, it's higher density therefore harder to form but the planking will certainly "nail" to it, both with glue and nails.
Just my two cents :)
Respectfully
That's exactly what I would have said.
  • 1 year later...
I use balsa a lot for this purpose. Although when fitting structural timbers in for the bow, it takes a little extra care to not fracture the balsa. I like it because it is easily sanded and hand carved if additional adjustments need to be made after being put into place.
- Tim
I have used balsa as bow and stern fillers for my current build HMS Supply. I found that after fitting the blocks painting on several coats of a PVA wood glue/water mix (allowing it to dry between coats) made the balsa firmer and better to plank on to as the mix seemed to soak into the balsa. I have used basswood a number of times before for the same purpose. I think the balsa is almost as good as long as it is treated in this way and it is easier to shape.
Edited by hornet
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
