Hope that the labeling that I did on the frames will keep things together. But I'm planning to start to glue up a frame after I get frame parts B, A, 0 cut out. I'm saving frames C and 5 till I figure out a little bit more on the scraf joints that I'm going to add, end frames that you can see a scraf joint on that is. Of course chocks will be added to those two frames also but those can be cut in.
Thanks for the Best Wish's everyone.
On cutting close, well hope that the fellows that drew that frames were true on their lines. In 1:24 scale my frames will be 3/4 inch thick. Adds a little to the sanding.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Finally, some tangible progress. It's been a bit of a journey for you to get this far. Looking forward to seeing more pictures.
Regards,
Grant.
  • 7 months later...
Everybody -- after a long break I hope to be starting back in on this in the next week or so. Wish me Good Luck in getting back to it.
Found out a few days after Christmas from my daughter and her husband that my wife and I are going to be a Grandparents in August 2014 or sometime like that. I guess that I should try to finish something that they might enjoy someday rather than a lot of wood and kits sitting around.
Later Tim
