This famous ship was under the command of Captain James Cook when he sailed the South Pacific and discovered New Holland (Australia).
PvG Aussie (Peter) Started modelling Jan 2022.  Joined MSW March 2024. Quote: Rome wasn't built in a day!
Current Build:  Piececool The Queen Anne's Revenge 1:250 Metal
Past Builds:       Artesania Latina (AL) Belem (1:75), AL Vasa (1:65), Scratch build Australia II BOTTLE (1:225), AL Bluenose II (1:75); AL Bounty (1:48),
                             AL HMB Endeavour (1:65), Trumpeter Bismarck (1:200), Border Models Avro Lancaster Bomber (1:32), AL Fokker Dr1 (1:16),
                             Das Werk WWI German U-Boat SM U-9 (1:72); Scratch build HMS Victory BOTTLE (1:530), Wolfpack PBY-3 Catalina (1;72),
                             Scratch build MS Sibajak 1928 BOTTLE (1:1150), Imai Kagaku Spanish Galleon 1607 (1:100), Brandenburg State Yacht 1679 (1/200),
                             HMS Endeavour (1/450) BOTTLE, ILK USS Enterprise (CV-6) (1/350), PLUS approx. 13 more ships in bottles
I started a new build yesterday! 😜
If you can't follow any of the content below, go to a more detailed build I did earlier, here.
As always, I started with a bottle and a set of carefully scaled plans.
Two pieces of wood (12mmx20mm).
Decided on how much of the top piece is needed and also where the shrouds would be going on the top piece,
so I drew under the top piece (All will be made clear later.)
Decided where the two 20mm Flat Head nails were going.
Up from the underside of the bottom piece of wood. (These are used to hold the two pieces together.)
Generally, away from the marked areas. Don't forget to leave them protruding a few mm.
Used my Dremel to cut out 2-3mm depressions under the top piece. 🙃
Cut a top plan of the ship and glued it to the top of the joined (NOT GLUED) blocks.
Start shaping!
Do the same with the side profiles.
Once done check symmetry.
Stop and admire your wonderful tiny achievement. :dancetl6:
TODAY
I added some rails (using Polystyrene 0.25 x 2.0mm strips) and started painting!
Using these paints.
Sat31st-1.thumb.JPG.96a8d636a652712ff84830ee6381d421.JPGSat31st-2.thumb.JPG.55be4e756d490b74b6550d245933d988.JPG
Don't forget the top edge of the bottom piece. (It helps hide the join.)
and during the whole process, remember to do a fit test of both pieces.
Sat31st-5.thumb.JPG.50b37806119a3736976ae44f5bae1585.JPGSat31st-6.thumb.JPG.ef22a6f9bdb40b0378d6c6472d35c41c.JPG
Tomorrow is Father's Day so I think nothing will be happening.
Congrats to all Dads.
Cheers,
:cheers:
Edited by PvG Aussie
Greeting All,
Making the details for the deck was very easy.
Progress has been made thanks to my scaled diagrams.
This one is used to measure and make masts, yards and sails.
To decide on the rigging, I just keep using the same diagram.
The little ship is coming together well, and it fits into the neck of the bottle quite easily.
The sail material has been stained with Vallejo Brown Sand paint
and is ready for cutting and attaching to the yards, tomorrow.
Till next time,
Cheers,
Not much interest in this one, but thanks to @CiscoH and @ccoyle for your support.
Last time I left you with masts up and not much else.
So here goes.
She was then ready for the sails, using white glue, and shrouds.
(Holes in hull, needling lines and glue in place underneath.)
27.thumb.JPG.fb1deeefdef4157151af16eb1d4027bd.JPG 28.thumb.JPG.f3088c8b3e2aa61e986c605c6545f5d8.JPG
34.thumb.JPG.f9d9badd04b44f33046401bc0e3fb8a8.JPG 35.thumb.JPG.36facac196254c074adc741bf7ccb60c.JPG
Time to put her into a clean dry bottle.
Bottom half first. Let it dry overnight.
Then, 'the cruncher', the top half.  😬
Let it dry overnight and then pull her up!
Add the finishing touches
and she is FINISHED!
Thanks again guys for your support.
Cheers,
Peter.
:10_1_10:
Well done Peter!!  Sorry to have missed this earlier.  You put it together quickly!
Makes me want to finish my SIB build.  I got a little stuck in how I wanted to represent the bulwarks in a thinned down version and just decided to start something else.  I wanted to get it thin, but then of course needed to be strong enough to hold the rigging.  I was originally trying to use thin plywood, and might try it again.  After building 1/700 scale ships, I have better tools and ideas on how to proceed with details like that.  Your build log is very inspiring!
Hi Mike @Landlubber Mike,
Have a look at my simple solution in Post #13 here. Simple and worked well.
Thanks for your great comments regarding my build.
Peter
