As I read through the documentation for the Hull project, I am confused how Toni came to 14". If the average plank size is 9", and the garboard is 1/3 larger, then the math is 12" not 14".  Can someone shine a light on this please?
jim
Edited by Jim M
In progress
Lady Eleanor by JIm M - Vanguard Models - 1:64
On hold
Norwegian Sailing Pram - Model Shipways
18th Century Merchant half hull planking - NRG
On the shelf
Muscongus Bay Lobster Smack - Model Shipways
Peterborough Canoe  - Midwest Products/Model Shipways
Batelina - MarisStella
Junco China - Disarmodel
Completed
Model Shipways Lowell Grand Banks
Grand Bank Dory - Midwest Products/Model Shipways
15 hours ago, Gregory said:
If you read Toni’s log carefully, she says the median width is 12, and widens to 14 at the stern.
@Gregory but is the 14 inches determined? if it 1/3 the. the size should be 16 inches.  12 + 1/3 * 12 = 16
is there some theory to describe this rule?
In progress
On hold
On the shelf
Completed
It is not so much a theory as it is a matter of practice based on the measuring of the spaced to be covered with the planks in a uniform manner.
Look at Toni’s log beginning at post 22.
Consider how you would go about tiling a uniform rectangular space.   All tiles the same size. Piece of cake.
Now think about how you would tile the surface of a sphere in a uniform way.
It’s a matter of filling the available space  at stern and bow with the number of planks that were determined to be needed at midship.  They will be wider at the stern and narrower at the bow/stem as well as having compound curves in some areas.     Toni shows the use of a stealer at the stern; a common practice.
The 1/3 bigger formula was only applied at midship for the garboard and broad strake.
The extreme widths of  all planks is determined by running fair lines from end to end .   The 14” measurement  was determined to be a good fit based on the fair run of the planks.
― Jimmy Buffett
Slow crawl:    Rattlesnake
Ok I think that that make sense.
To summarize, we determine our plank size, and according to Toni's post, it can be anywhere between 4" to 12" for the time period. Correct?
Then after we make a decision we need to run a fair line for the garboard that is parallel to the wale, and from there we can determine the size of the stern for the garboard, and stem? Is that correct?
In progress
On hold
On the shelf
Completed
Perfect that makes sense now. Thanks @Gregory
In progress
On hold
On the shelf
Completed
