I am excited to start with my next project, the planking tutorial. Prior to receiving the kit, I had the manual printed.
I am impressed with the kit contents and how it was packaged.
Next I mounted the build sheet, on a piece of 1/2 foam I had as a build board using some spray adhesive.
I need to pick up some markers, and chart tape, but I am eager to get this project moving forward this week.
jim
Edited by Jim M
In progress
Lady Eleanor by JIm M - Vanguard Models - 1:64
On hold
Norwegian Sailing Pram - Model Shipways
18th Century Merchant half hull planking - NRG
On the shelf
Muscongus Bay Lobster Smack - Model Shipways
Peterborough Canoe  - Midwest Products/Model Shipways
Batelina - MarisStella
Junco China - Disarmodel
Completed
Model Shipways Lowell Grand Banks
Grand Bank Dory - Midwest Products/Model Shipways
Looking forward to following along.  Good luck.
thank you
In progress
On hold
On the shelf
Completed
I think you are going to enjoy this build.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Good evening,
After a challenging week, I was able to get some modeling done tonight.
First I labeled the parts so that I could remember what is what :)
Next I then cut out the keel, keelsom, stern post, fore keelsom, stem, stemson, deadwood and the l-piece from the kit.
I then used some double sided tape to help dry fit the piecesIMG_2403.thumb.jpeg.02895f5f99657f1cfbf885a11eb129b9.jpeg
Next I focused on getting the stemson and stem lined up correctly with a nice joint.
I then removed the char from the pieces, to work on the fit. I ended up making a couple sanding sticks after trying to use an old blade to scrap off the char. The results are as follows:
IMG_2405.thumb.jpeg.6bb4e98d598c7cd20713ec10efd40023.jpegIMG_2406.thumb.jpeg.5b3de4d11c9a8731d0609c1bd92a891b.jpegIMG_2407.thumb.jpeg.00fd5df8337b344572d096451244a671.jpegIMG_2408.thumb.jpeg.f4d1fa9477bef3bfb5cd5fdb4700e5f9.jpegIMG_2409.thumb.jpeg.7d7f44bd397cc9dfd870b50deb4bfce4.jpeg
Finally the fit for the stemson to the stem now looks like:
I continued per the manual with the following items to get a nice fit. I realigned my keelsom to the its matching bulkhead location, and then worked on the fore keelsom to get it to fit. and match its bulkheads.
The final result is IMG_2413.thumb.jpeg.a80a3846159bfd0f59662370ea51d9ea.jpeg
Finally today, I marked out the rabbets. I will let it sit overnight before I make some sawdust and cut them out.
jim
In progress
On hold
On the shelf
Completed
Good afternoon,
I made some progress on my kit today,
First I added the rabbet
Next, i cut out the 4th and 5th bulkhead so I can get a better visualization of the  the rabbet on the stem, and stemsom.
I  was able to get some good contract with a sample 1/32 piece from my last project.
IMG_2430.thumb.jpeg.020febe642b88aebf418697b20760b1c.jpegIMG_2431.thumb.jpeg.be184b4c5d8bf3e52d3ccca8ef38e197.jpegIMG_2432.thumb.jpeg.f5e39505f1f4f5f444272c2d79fb9980.jpeg
Next I spent some more time deepening the rabbet, and getting the angle right. I also use an eraser to remove some of the pencil marks
Hopefully you can see the transition to 90 here in the stem
Finally I started the gluing process
IMG_2438.thumb.jpeg.5bbf0c62166e1058aa5f36b1ce7f1e20.jpegIMG_2439.thumb.jpeg.07f0a1d4f1423d683fe74380fbe5e83c.jpeg
I did break the stem post as I had to move it and it was setting up faster than expected. I noticed my crafting room was 78 :(
I also found that the stem was lifting, so I used a couple or 3x2x1 blocks to hold it down.
Cheers
jim
Edited by Jim M
In progress
On hold
On the shelf
Completed
Update here is the better picture of the glued keel. you can see where the keelsom broke.
In progress
On hold
On the shelf
Completed
Good evening. Here is my next update.
Today, I extended the slots on the keelson.IMG_2452.thumb.jpeg.3369fc792b14895b452aefad475974b6.jpeg
Next I glued in the frames in two batches.
Batch 1 -> Frames E, C A, 1, 3
Batch 2 -> Frames -> D, B, DF (O), 2, 4
Next I added the fillers, and knocked off some of the char on the bulkheads.
I then marked out the bearding line use frames G and H as guides. I then took a french curve to make the curve.
Next, I shaped the bearding line by marking 1/32 and then blending in the curve.IMG_2459.thumb.jpeg.309b5099b27aeb1485cb7bc05625cde0.jpeg
Next i extended the rabbet along the keel until the the stern post. This rabbet is 90 degrees.
I then glued in the deadwood, sternpost and L-shaped pieces
Finally I glued in F and G frames. I initially had H glued in but I was a  little hasty and removed it before it set.
I will let this firm up over night and continue on the next step tomorrow.
Cheers
In progress
On hold
On the shelf
Completed
Good morning,
I know it has been a while since I last posted. Real life has gotten in the way.
By November 1, I had completed the following:
I started with finishing adding the supports and the transom. Before adding it, I realized I glued the L-Piece onto the board incorrectly, so I had to pull out the isopropyl out and fix its positioning. I did use a square to line up the transom.
For the next few days, I spent some time getting the top line correct. I used chart tape to help visualize the curve. From there I use a square to transfer the line to the bulwarks.
IMG_2476.thumb.jpeg.a3aed2425738a3aa930b18fda8d324dc.jpegIMG_2477.thumb.jpeg.da5384d1646e2340bc81aee095ea9809.jpeg
If you notice, I had to add a shim on 5a and AF. This is because I deepened those connections.
Overall I am happy with the line.
Last week I broke down and purchased a Dremel.  Thus last night, I finally got back to the project, and I started with shaping the top line. I purposely did not go all the way to my marks, so that I would have some room if necessary after planking to get the curves correct.
Here is the stern section. It will require some more sanding, as there is still a high spot.
The bow also is looking not bad.
Here is a view of the sanded top line.
Finally I started to fair the bulwarks from DF -> AF.
The curve is starting to take shape and I am getting some good contact with the plank.
Frame 4A is still not correct. I may need to add a filler to fix the line a bit.
Also when I tested the fit along the top line i noticed I had a gap as frame 4 is causing a high spot.
Overall the fairing is going well. I still need some more work on the bow half of the hull, but I decided to walk away last night as I do not want to rush things.
Though I did notice that my bow rabbet is a little shallow so I will deepen it too.
Cheers
In progress
On hold
On the shelf
Completed
Definitely take time fairing the stern end. Take a look at some of the nice examples to see what it should/could look like and really make sure you can lay planks smoothly. I probably spent 10-20x longer fairing the last inch of the hull than I did the rest of the hull (didn't help that I first did it without the transom and then realized I took too much off some of the frames and had to add wood back). In retrospect, I also had a bit of a discontinuity (elbow) in the bow end that I probably could have seen if I had more patiently dry tested some planks. After now 2 1/2 plankings (well, maybe the Dory only counts 1/4) I'm getting a better sense of what plankings should look like.
Edited by palmerit
@palmerit
I am starting to understand how planking and fairing should be done now. I am really loving my dremel with the wand attachment. I keep it at under 10k in speed and go slow. I am also using a 120 grit sandpaper so that is not that aggressive.
In progress
On hold
On the shelf
Completed
Good evening. A minor update on the planking tutorial.
Today finished fairing the bow portion of the hull. I was able to get a nice curve on the hull.
Here is a photo just about the second strake.
This is approximately the second strake.
The garboard
Next, I started to tackle the top line in the stern.
You can see I have a low spot on frames E and D.
I used thread to give me a nice line along the bulwarks.
More sanding, and I am getting a little closer.
The lower top line is starting to curve nicely a little high spot on A.IMG_2508.thumb.jpeg.b458e0e84679142280808260490ea53f.jpeg
After some sanding with a long sanding block I was able smooth out that high spotIMG_2509.thumb.jpeg.fdc1e7188e45ba7b4048dcc757ac2974.jpeg
Here you can still see the low spots on E and D.
I am pretty close here, I need to thin out G a bit more, and get a nice line. I started to address the the upper part of the top line to blend nicely into the transom.
Have a good night.
Cheers
In progress
On hold
On the shelf
Completed
Good evening a minor update for today.
I did some more fairing of the hull and i focused on the stern. The sample board is fitting nicely.
IMG_2515.thumb.jpeg.7d2121ba9e733a54ded2d26ca3e031d1.jpegIMG_2514.thumb.jpeg.387ec4dbf0e8450e60acd7ffd4e4a4c6.jpegIMG_2513.thumb.jpeg.14671e07096adf60e68b4a88fa8f86f9.jpegIMG_2512.thumb.jpeg.0f2e6f865a8c546fe35cf2f7edfe4249.jpeg
Tomorrow plan is to get the counter in and finish the fairing.  Hopefully I can get the planking bands identified
jim
In progress
On hold
On the shelf
Completed
Kurt
I am @kurtvd19.  This build is adding some clarity to how ships should be planked.
In progress
On hold
On the shelf
Completed
Good evening.
Tonight I added the counter. I was a little aggressive with the sanding and I added a shim to get a solid connection.  Secondly i mapped out the wale and added a string line to get the bottom into a nice curve.
Have a good night.
Edited by Jim M
In progress
On hold
On the shelf
Completed
Good evening, I spent some time relining my wale line this afternoon.IMG_2517.thumb.jpeg.5492bf13c61d1c7acf728cbbd0404cf9.jpeg
I received some better chart tape yesterday, so I was able to map out the full wale, get the lines correct.
The calapiers helped in visualizing the wale, and where it needs to be. I ended up using some green marker to mark the final positions.
I also did some more fairing on the stern to make it a little more smoother. I suspect I may need some more when I get closer to the deck.
I then marked out the 14 inches at the stern for the garboard, and the 12 inches for frames D - 3. I also spent some time making tick sheets.
Here is the stern
And here is frame B
After I was happy I took a break to look at the garboard how it is going to lay down.
I then marked out and cut out the first half of the garboard on a piece of scrap planking material. I definitely did not like this result.
I repeated the process and you can see that the scribing is larger than my fist attempt.IMG_2524.thumb.jpeg.00097063f730d87d2deba699bdc118dc.jpeg
I also cut the plank outside of the lines this time so that I can shape it a little better.
After cutting it out, I it definitely was a little better in the fit category. I had to do some sanding.IMG_2526.thumb.jpeg.b53d82e4134fcc49ed5d492b64af99b6.jpeg
However, I am not fully satisfied with this plank; I did not cut the notch correctly, and the plank does not sit in the rabbit correctly.
I decided to take a break tonight. However, I think I am going to redo this plank again.
Cheers
Jim
In progress
On hold
On the shelf
Completed
I ended up redoing that first plank too - for the same reason. I ended up buying some more basswood sheets so that I could redo planks as often as I needed. I found that after redoing a few, I would have used all the basswood that came with the kit.
I always made by planks too large and then just sanded them down to shape them. Probably a hack. But when I tried to precisely mark out the shape and cut them they were always off, and if they're too small or there's a gap you need to start over. Making them wider and longer made it easier to iterate. I definitely used the ultimation slicer a lot.
One challenge I found is that you need to wet down to shape. But when wet, you can't sand or cut.
Edited by palmerit
I found on the second plank having the ability to iterate over it was better. When I worked on the transition, I placed my scalpel in the wrong spot and it slipped.
How did you integrate the slicer on these custom planks? Just for the length?
In progress
On hold
On the shelf
Completed
Good evening,
The countdown has begun for dead turkey day; I have a lot to due this week, with brining the turkey, making apple and pecan pies, along with my cranberries, and stuffing. However I was able to get some work done on my planking project.
As a recap, I was not happy with the garboard last time. I had already cut two planks, and they just where not working. After taking a couple days from the project I was able to get the offending plank done.
I first re-scribed the plank. I found that using a small piece of wood I was able to properly burnish the rabbet a lot better, and the length in the template was much more accurate.
I then cut the plank a little oversized and used my planner and sanding sticks to bring it the right size. I would check against the marks I made at each the bulkhead.
As you can see below, I was able to get the full garboard mocked up nicely using this technique.
A close up of the stern
A close up of the bow.
Next I then glued the planks to the model.
I then proceed with the bow for the first strake.
However, after I pulled the clamps I noticed that the there was a gaping whole between the planks.
It took me three tries to get this plank correct but I was able to finally obtain the results I was looking for. With this plank I decided to wet the plank as I was putting the clamps on for a dry fit so that it would bend a little better.
After waiting for the plank to dry, I then glued it on. I did forget to add the pencil to simulate the caulk but I will go back and do it in the morning.
Cheers
Jim
In progress
On hold
On the shelf
Completed
Good afternoon,
Sorry for the lack of progress the last week, I was in Vegas for a week long conference for work. I was able to get the other two planks in for the first strake yesterday. IMG_2779.thumb.jpeg.b2fa31e8dc4b4ca4b832b80a06cc2b7f.jpeg
My next step is to start to determine the planking bands.
In progress
On hold
On the shelf
Completed
Good evening, I spent some time today determining the planking bands.
I was a little confused on the the counter, but after re-reading the instructions a few times, I noticed that I should keep 4 planks at 9" for the upper band, so I added a mark there.
For the bow, again it was a little confusing, but I ended up using the distance from the first broad strake, to the whale using bulkhead 5a, and there i created the marks for the bands there.
On the stern, I did not calculate the split, but after rethinking it, I decided the stern plank should be 11", and I set the second band 1/2 way between the first strake, and the third belt. The plank count turns out to be 4.5 per band, so I will create a steeler between first and second bands.
After correcting for 11 inch planks at the stern, the curve for the third band will need some adjustment tomorrow from left of B.
Cheers
jim
In progress
On hold
On the shelf
Completed
Good evening. I made an adjustment to the planking belts. I am going to sleep on the change before making the final commitment.
Cheers
In progress
On hold
On the shelf
Completed
Good evening, and Happy New Year!!
After the hectic holiday and minor illness I am able to get back to my planking project. Tonights objective was to get the planks marked on the bulk heads.
I ended up taking the measurements from the first strake to to the bottom of the whale, as I noticed that my belts where not as even as I would like. Secondly I really struggles with the obsolete imperial measurement system so I had to make some calculations. So going back to the document we know we want our plank width at B, A, and DF to be 9 inches. So we know that 1 inch = 25.4 mm. So our width would be 9 * 25.4 mm = 228.6 mm. Now we need to adjust for the scale, so we need to divide by 48. Thus 228.6 mm / 48 =  4.76 mm as our maximum width.
Similarly for the the maximum width at the stern post to be 11 inches (279.4 mm) our value is 5.82 millimeters.
Thus for my DF bulk head it measured 54 mm which works out to 54 / 12 = 4.4 mm per plank. Now B and A came to 56 mm each so the width is 4.7 mm or ~ 9 inches.
Below is the marking of A and DF after doing my calculations.
This is an example of the transfer of planks to the tick sheets.
The red on the tick sheets is my marks from my plank belts. These we transferred prior to splitting out the planks. Though I do like the concept of planking belts, it is obvious I could not get them even and you can see the challenges on the next photo after completing the planks marking.
I plan on adding a steeler between plank 4 and 5. For the bow, my plank width is 2.0 mm. This is less thank half of 4.7 mm which is 2.35mm, so I will need to plan at least three drop planks.
Have a good evening
In progress
On hold
On the shelf
Completed
Good morning,
Yesterday I was able to make some more progress. First I started with marking the joins for the planks using the 4 shift pattern. They are marked in green.
Next I marked out the steeler, to get some visualization, of approximation. From what I gather there 8 planks that will hit the stern post, as the last belt meets up with the counter.
I decided to try the compass method for scribing the hull line. I must admit I really like this process that the tracing method as presented for the garboard and first strake.
After cutting the plank, the dry fit looks good.
After trimming the joins, I then glued the plank. Note, I changed glues from Tightbond, to Gorrilla glue. I am liking the Gorrilla glue better, and it dries clear, and is a little more tacky.
I continued with the other two planks.
The final three planks looks as follows:
One thing I did notice with the other two planks it was a little cumbersome doing the scribing after mounting the first plank. So in the future I am going to template the planks and cut them out first, then dry fit before glueing them in place.
In progress
On hold
On the shelf
Completed
Good morning, on the 22nd I was able to complete the second row of belt 1.
This time I worked on each plank and fitted them before gluing.
Here I am dry fitting the plank closest to the stern.
Next I fitted and glued in the bow plank. At the same time I glued in the stern plank.
Finally the middle plank.
In progress
On hold
On the shelf
Completed
Good morning,
Yesterday, I made some progress with the planking of the third row yet, at the same time I also took two steps backwards.
First I scribed and cut the planks for the row. Notice I made them a little long, so that I can make the join match nicely.
Next I bent the bow so that I would not break the plank.
Next I cut the joins using my cutter
The fit came out nice.
I then glued on the bow plank
Next the stern plank.
Next I dry fitted the plank that joins to the stern plank and I realized that I missed a plank (facepalm). I also notice the second plank on row two did not fit just right so I removed it and placed in a new plank.
Further inspection I noticed that the first and second bow plans broke at the bow, so I decided to redo these planks, marked with the x.
Before placing the planks down I did some more faring to smooth out the joins better. After that I glued in a new row one plank.
Next the bow plank for row 2.
Yet another step back this morning, I removed the clamps for row 2 and I the bow plank broke again. I will need to remove it and redo that plank.
In progress
On hold
On the shelf
Completed
