There's some useful information and leads to follow in the conversation here:
It touches on some useful source books for modeling British warships of the era. You may also want to check if the original plans for the Triton or other vessels of its class are available online (wikimedia has a ton of British warship plans), they would probably give you a good idea of the mast locations and angles.
Nice job on the windows!
Thank you al around
On 12/23/2024 at 10:07 AM, James Flynn said:
I can't find the plans for the rudder I looked all through the downloads 3 times and I guess I'm missing something but I  can't find it
Hmm.. that's weird.  Are you using the plans here on MSW from the group build?  IF so, check the group build area for the full hull model and have a look the logs.
I have looked through all the downloads offered in the group build logs 3 times and unless I'm mistaken, I can't find it
I can't find them either.  You might look through some of the "finished" logs and see what they did.  That's about the only advice can offer.  However, I do believe that at that time, most British frigates basically the same design for the wheel.
I'm having a bit of a problem I'm hoping you all might be able to help with. It aperies the plans I followed may be off concerning this. I build my windows to match the plans I downloaded but the hole frame does not fit as it should. looking at this Kit build the outer windows are supposed to hang over the outside of the frames but mine are almost completely inside they seem too small. not sure how to resolve this
