First time modeler trying to use Chuck's plank bending method on the Lady Nelson.  My question is what's the technique for getting the sharp bend required on the last couple of inches of the plank to get around the first rib and into the bow?  I'm getting the bend on the rest of the plank OK, but I've broken 3 of them trying to get that last bit in.  I think that if I don't get the bend sharp enough then CA glue isn't going to be strong enough to hold the end of the plank in place.
Any tips will be greatly appreciated!
If wood is breaking before making the bend, it's not hot enough. Bending wood is a matter of getting it hot enough that lignin plasticizes and it doesn't really matter which way you get it hot, you just need to get it to that temperature.
Steaming is good because it gets the wood uniformly up to boiling temp, but you can use an iron or a heat gun.
