Creating a panel of windows and noted lots of varying opinions in the build logs on glue for acetate to wood (and definitely not CA glue due to clouding of acetate) and needed a definitive answer. I am sure that epoxy would work but want about contact cement?
Thanks!
Julian
Current: Mamoli - Friesland
Finished: Billing Boats - Bluenose
Mamoli - Santa Maria, Billing Boats - Dutch Sperwer
On Hold: Caldercraft - Bomb Vessel Granado
You might try Duco Cement. This is nitrocellulose dissolved in acetone. It soaks into wood and makes a good bond, and it does adhere to smooth surfaces pretty well.
Of course you want to use small amounts and place them away from the window openings.
The warnings on the tube say to not use it on polyethylene or polypropylene plastics, but doesn't warn against use on acetate. But I expect it will craze the surface - that should make it adhere better.
Phil
Current build: USS Cape MSI-2
You could dissolve some of the acetate in acetone and use this as liquid cement. If the wood surface is still raw, you can use this solution also as sealer, to which then the acetate should adhere well.
Thanks for the replies!
I actually did an AI search (not a Google search) and found out that a hot glue gun can also work.
Not so much fun to work with (as it clumps up and solidifies quickly) but it got the job done.
Julian
These hot glues work for almost everything, but 'technically' they are not quite correct solutions. There is also the risk that when the plasticisers diffuse out, the bond becomes brittle and the glued parts fall apart ...
