Here’s my first attempt at a build log. I completed the Dory last month, and now it’s time to move on to building the Pram. I learned a lot from the Dory, which was my first wooden model. The most important lesson I learned was to slow down and take my time to figure out the problem before moving on. I rushed a bit on the Dory, and it shows. So, this time, I plan to be more deliberate.
I also need to take more photos in between steps, as I don’t have many considering how far along I am.
The first few steps were pretty straightforward. The biggest issues I had with the bow and stern transoms were figuring out the correct sanding direction for the straight edges. The instructions weren’t very clear on how to face the edges when sanding the angle. I had to refer to the included schematics before I figured it out. I found it very helpful to print the page at 125% to make it more clear, and then it was easy to see how to sand the edges.
Next, I sanded the knees and created a flat 90-degree edge so they would sit flat. I spent a lot of time on this step, holding the knee on my square and using a sanding block to run parallel to create the edge, as shown in the book. In my opinion, there has to be a better way. I’m already trying to think of a jig I can make that will allow me to secure the knee easier and have the sanding block in a groove or channel to help keep everything perfectly square without damaging my fingers, etc.
Once I had the transoms built, I proceeded to assemble the building frame. This almost killed me. Not only were the two middle supports not square, but the aft transom holder wouldn’t stay in the slot. The slot was too big out of the box. I cut some small 1/8-inch basswood strips, sanded an edge on them, and wedged them in the best I could to get a tight fit. I also added a spare strip of basswood along the base of both middle supports to help secure them and keep them straight as possible.
I discovered that the most straightforward way to shape the three bottom planks was to wet them and then attach them to dry ones. Although I haven’t invested in a bending iron yet, the more I practice this technique, the more I realize it’s a necessity. It’s frustrating that I have to wait for hours for the planks to dry completely before I can proceed to the next step. However, I managed to dry the planks and glue them to the transoms. The most challenging part was ensuring that the transoms remained straight and aligned with the guides while the glue was drying. Despite these challenges, I believe the transoms turned out well, not perfect, but better than my previous attempt. As long as I’m improving, I consider this a positive development.
IMG_0937.thumb.jpeg.07203590d1daa79fc0783cdf9a985e36.jpegIMG_0938.thumb.jpeg.ed00c16188fbbd098e88bd4d054cde86.jpeg
I’m eager to hear any suggestions or criticism, as they are the sole reason I’m undertaking this blog. I appreciate your input in advance.
Have fun with this little boat, Jasennord!  It was a nice ship to continue to learn skills on.  Although I don't recall the exact issue now, I'd have to look back at my build log to hopefully jog my memory, but be cautious when you get to the point of trimming the transom, as I don't think the kit's measurements were exactly accurate to what you really needed to do.  It looks like you have a great start on the planking!  Enjoy!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
No matter how long we've been at it, there is always room for improvement. Often progression is not linear. So, if there is a setback, don't be discouraged. You are still on the learning curve, as are all of us.
