Hello, colleagues!
In the first version of the Forum, I was driving his report on the construction of. Alas forum collapsed, and with it my theme too. It was pretty sad.
I will try to regenerate the report to present all the main stages of construction.
So it all began
At the request of the customer's vehicle should look old. Therefore, all the elements to grow old with oil followed by the application of bituminous patina.
Gradually, along with the ship's hull was doing small things: guns
Feed shell:
Pipe galley:
Edited by Roman Roganov
Hi Roman
Congretulations on a stunning model. I am currently building the Le Carmaret, but will follow you on this model when i am finished.
Wel Done !
Hi Roman
Your model look good I know how much hard work you must have put into it, I am building the Bounty also
my model is the Del Prado version came in fortnightly and I have all the issues now started her about 5 years
ago it all takes time
Regards
Allan
Hi Roman
Looks mighty fine - keep up the good work - I am currently in the final stages of my bounty !
Love it ........you are doing something I find very difficult to do, and that is to simulate ware and tear ,my overriding impulse is to keep everything as pristine as possible.
  At what stage do you simulate the ware and tear....and what is it that you apply to give it that aged look.
  Thanks for posting,
           Jack
  • 3 months later...
  • 5 months later...
great build mate did you make the cabinet in front of the wheel yourself or is it in the kit? also how did you do your treenails?
