I am building the revel 1\96 Spanish galleon, wondering what is the best way to fix the spars, they are warped. I guess I could heat them but wondering if there is a better way, any ideas?
Depending on how much they are warped, you can sometimes straighten them with the same rigging lines.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
The smaller ones had be heated next to an iron and formed to shape.  I tend to now, as Jud said, use them as patterns and make them out of wooden dowels.
The larger ones should be two-piece assemblies.  With these, you can put a small steel, or wooden rod in them and glue the halves together.  Makes sure to use a lot of clothes pins to clamp them down with.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
If you split the stock for the yards from a plank - using a fro-like tool - the yards will be less likely to bend or twist - as this follows the grain - something a dowel is hit or miss with.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Hello, I have managed to fix such bended plastic pieces by dipping them into very hot water (actually, boiling) and setting them to the correct position with two pliers. It also may be a good idea to try the technique on a piece of sprue to set the correct temperature before doing it on the actual piece.
The boiling water is hot enough to make your piece pliable yet not that hot to make it lose its correct shape. I would not try heating a plastic piece in another way; it may melt or, even worse, can ignite if heated too much.
Edited by Doreltomin
  • 2 months later...
Vett,
I am not sure if the boiling water technique worked or not, however, Revell has an amazing customer service that you can request replacements from. If the kit is from the US then it takes only a couple of weeks to get the replacements, otherwise, if it comes from Revell Germany, it can take up to 12 weeks. I have had to request warped, broken or missing pieces on numerous occasions and have yet to pay for them. The downside is that if the model is out of production, then they rarely if ever have the part. Hope this helps, If not now then possibly in the future.
Steve
Current Build: Merit 1/48 Early Eco 80' PT Boat and Imai 1/50 Catalan Ship
Revell 1/196 USS Constitution (My oldest son's school project)
Revell 1/72 Hanse Kogge
Revell 1/50 Viking Ship
Revell 1/72 U-Boat
Zvezda 1/72 English Medieval Ship Thomas
Revell 1/90 The Nina
