 Running thread in the dead eyes and blocks are some what fairly easy but what is the easiest way to thread tiny dead eyes and blocks? It's like the thread is larger the drilled holes even using tweezers and a magnified glasses. :(
you might try thr fly fishing shops for small thread or fine fishing line. Make sure its flexible enough to lay in the deadeyes correctly though. BILL
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
The deadeyes in the picture below are 2mm and 3 mm. So it can be done. I used sewing thread after having taken a #80 drill bit to clean out the hole. I use beeswax on the end of the thread to stiffen it up and a magnivisor to see what I'm doing.
Cant beat SG on the end of the thread so easy, but use the very thin viscosity grade
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Simplest jig ever – take piece of telecom cable and remove thin wires from inside it is great for pass thread trough block or deadeye.
Space jig for lanyard
Tadeusz
My models:
From kits
Vasa, HMS Victory, Le Solei Royale, Friesland
From scratch
HMS Warrior 1860, Esplanade, Grosse Yacht
Norman’s ship, HMS Speedy, La Royale
Peter von Danzig
Polacca XVII cent.
Current project:
SS Savannah 1818
