Continuation
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
3.7 . Rigging of guns
Best regards,
Garward
Here so the gun carriages of the Spanish guns made presently (a museum "Royal Artillery Factory in La Cavada", Spain) look.
Best regards,
Garward
4 . COVERS OF CANNON PORTS
4.1 . Wooden details
Covers of cannon ports of the 1st battery of 14х14 mm in size are made of a pear and padauk
Best regards,
Garward
4.2 . Metal details
Loops from a brass wire with a diameter of 1 mm, an axis - brass nails with a diameter of 0,75 mm.
Eyes from a brass wire of 0,5 mm, nails with a diameter of 0,5 mm.
Loops from a brass foil of 0,3 mm.
Best regards,
Garward
Continuation
Best regards,
Garward
4.3 . Assembly
In the beginning wooden details are stuck together by glue cyanogen, then the knife imitated seams between boards and metal details are established.
Best regards,
Garward
Continuation
Best regards,
Garward
4.4 . Ready covers of ports.
Ready covers of ports after impregnation by linseed oil.
Best regards,
Garward
4.5 . Installation of covers of ports on the  hull
Covers of ports were established on the hull after construction of gallery and finishey processing of the deck.
Best regards,
Garward
Hi Garward!
When you are edge milling little pieces like these, do you have a special way to hold and guide the pieces, or are you using your fingers? Does the shape of your aluminum fence allow you to use your fingers without any danger? What rpm is the bit spinning at?
Thank you for re-posting this info. Your imaginative techniques and amazing skill are inspiring! You sir are one of the treasures of this site.
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Continuation
Best regards,
Garward
Hi Garward!
Thanks for an assessment of my work! I these details held when milling (speed of rotation of a mill about 3000 turns) fingers if strongly not to press them, danger minimum. However, time of their production, but the whole fingers increases :) .
Best regards,
Garward
5 . GALLERY
Replacement of plywood and cast details wooden (pear) proceeds.
5.1 . Gallery overlappings
On a photo without No. gallery drawing from a set is shown
Edited by Garward
Best regards,
Garward
Continuation
Milling of end faces of overlappings is executed on MF 70 milling cutter by means of shown below extras. Mills are made of nails with a diameter of 3 mm.
Best regards,
Garward
5.2 . Sinks
DSH/E electrofret saw, pear, inserts from ebony fine line interline interval; ready sinks are covered with linseed oil.
Best regards,
Garward
Continuation
Best regards,
Garward
5.3 . Gallery roof
Best regards,
Garward
Continuation
I made one option of replacement, not absolutely it was pleasant - I made this detail on another.
Best regards,
Garward
5.4. Windows
Are cut out from a pear 1 mm thick interline interval
Best regards,
Garward
5.5. Gallery assembly
Best regards,
Garward
Continuation
All details of galleries are established. Columns from the Australian cherry (Cherry Ballart).
Best regards,
Garward
6 . FENDER GUARD I LADDERS
Are made of a pear, fender guard are processed by a black pigment
Best regards,
Garward
7 . DECK DECOR
I embellished the deck (easily patinated brass strip) a little.
Best regards,
Garward
Hello Garward,
Just one word "Wow".
Your dedication to all the tiny details contributes and inspire all us to push the limits of perfection even more,
 I’m really looking forward to see the latest Montanes updates  :)
Edited by GTM
Best wishes, Theo
Current Project:
Santisima Trinidad -> Build log
Finished Projects:
Smit Rotterdam -> Gallery
Hello Garward,
Hi, Theo, many thanks for an assessment of my work!
Best regards,
Garward
8  Instalation of details
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Wheel installation
Best regards,
Garward
Continuation
Channel board installation
Best regards,
Garward
