Friendship Sloop by DRW-FJ40 - BlueJacket Shipcrafters - Scale 1:12
I finished the second layer of planking. I wasn't real sure how to handle the transition into the keel and ultimately I just transitioned to a single 1/32" plank and then transitioned to the first layer of planks just past the garboard strake. I did this to keep the width of the keel per the original plans.
I put a coat of primer on which revealed a few areas that still need a bit of work. Mainly that transition around the garboard strake. I'm using model expo paint applied with a brush. On some of my hulls I've gone for a highly polished surface and I didn't want to do that here because I plan to paint it and I want it to look vintage ~1910 & still be able to see some of the plank lines & I think a sprayed and polished paint job would look like a modern fiberglass hull.
Anyways, here is where I'm at & I'll work on a few spots and then start the deck planking. Nice to be moving on to another phase.
Link to comment
Share on other sites
Looking good.
Bob
Current build:  SS_ Mariefred
Link to comment
  • 6 months later...
Well... I'm not breaking any speed build records here but I have made some progress. deck planks on, trimmed & stained. I kept fiddling with the hull finish to the point that you can no longer see the plank lines through the paint... not what I had intended but at this point, I have a fairly decent shape and it has enough slight imperfections so as not to look like a fiberglass hull and not so much that it looks like a botched model.
I had resigned myself to the idea that I'll need to put a new mahogany veneer on the transom so I figured I'd paint the one that's on there and see how I liked that look... and I like it... I think I'm going to keep the paint the same color as the hull.
Link to comment
  • 2 years later...
I have made some, although looking at the date of my last update, the progress I have made isn't too impressive. I have the cabin on & seats, combing in. I did design and 3D print portholes for the cabin. I'll try to get some pics up this weekend. I 3D printed some portholes to fit the curvature of the cabin. I did them in plastic to make sure I had the fit right with the intent of printing them in brass but... probably will just paint them.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
