Hi Scott,
many thanks, your fine comment is highly appreciated
Looks like you are having a bit the same Approach to the model building Hobby as I had at that age, also with two kids  and "hundreds of ideas in the head".
Your technical background experience is just right for doing your own made steam driving equipment, and I`ll be eager to drop into your log from time to time.
Ist only a Feeling from seeing the pics of your kit introduction, the scale 1:50, the size of the model and the tubing for the intended Boiler outer tube......., Presume that you may have a Problem with space and the too high Center of gravity with a Boiler full of water, but I trust you may find a good solution on that. Wishing you all the luck and good success with your project
Nils
Current builds
-Lightship Elbe 1
Completed
Wow, 15 mm bore and 20 mm stroke, times 6.  You should be able to drive a bicycle with that.
Bob
Current build:  SS_ Mariefred
  • 3 years later...
Hi Scott,
I must apologise, as I somehow missed to answer your post of 27 th Jan.
Thanks very much for your nice words....
Nils
Current builds
-Lightship Elbe 1
Completed
