Mike Dowling
Everything posted by Mike Dowling
  1. Just to let you know out there that planking has commenced!!!!! I decided n the end with various advice to do the first plank according to the strange instructions. I can see some logic to them because of the open starboard side. I do have the advantage with the OcCRe kit over the AL kit that mine is double planked which theoretically means I can cover up my mess second time around. Anyway, just wanted to let you know and I will add some pics when I have done a bit of 'trimming' - not in the nautical way but with a knife!!
  2. I am going to throw all my toys out of the pram in a minute!!! Have a heart!
  3. Hi there, I think you should be grateful for one layer but, having said that I reckon two layers gives me the chance to cover upper the mess I make first time. Dom and I have been having an off site discussion about all this. I can't think it would make much difference if you do a second layer, the veneers are only 0.6mm ish and I think I would rather do that than copper.
  4. Dom, you are quite right. The plans look nothing like the photo of the ship. What I will try and do (never mind the copyright!) is send you a couple of pics from the wonderful instructions and see what you think from there. CA,CF and anyone out there who can help me, do feel free to join in. I am very concerned, having made the mistake before is not to laterally bend the strakes. CA yes, I think it is the wire for the lamp - nothing exciting! And I know I am going to historically wrong and I don't seem to have as many metal bits as you, I really do like the shiny brass bits so I may be a complete peasant and keep them shiny so there!!!
  5. Dom the bit of anchor rope coiled up neatly on the deck. On Al's and mine your coil goes down through the top and middle deck and gets coiled up neatly on the bottom deck.
  6. I don't know which electric tool you mean, is it mine or in Dom's picture? Anyway this plank oops sorry, Strake. What it says in my wonderful instructions is that above the level that I have put it I should infill with wedge shaped strakes until flush with the bulwarks front and rear. These will be covered with the second layer which starts at a slightly lower level than the top deck and I quote ' The first lining strip must be glued into place snug against the top of the sapele wood coloured lining, completely straight and parallel with the floor. Complete the lining until you have covered the bulwarks at the stern and bow'. This upper lining is done in lime wood veneer and is supposed to be painted in the end. The lower part is sapele veneer and will run in the same way as the first layer. So, I don't know if that makes sense but it is what it says. I quite understand CA your confusion about plank bending. I have read loads of different approaches as it seems have you. I have used up until now mostly on larger wood pieces than planks the 'Dowling' method. This involves soaking the piece to be bent for a while. Test it for flexibility gently by hand. If not bendy enough soak longer. Eventually the wood is supple enough to bend to shape using fingers. Then I either weigh it down and trap it between various household objects to hold it in place until dry or, apply it whilst damp to the model, glue it and wait for it to dry. The problem with ply is that it can delaminate but it has worked for me on thin wood and that is how I lined the inside of the bulwarks, (see previous pics) Neither I nor my good Lady own curling tongs and I only have a teensy soldering iron. I thought I might try using my hot air paint stripper which is useless for stripping paint. I do have a manual plank bender but I have found that this does tend to 'spread' the edges of a plank and you have to be very careful not to cut right though. Whichever way you/I/we use it is a long process. You have to wait for wet wood to dry otherwise you get shrinkage problems. So my clever friends, what next?
  7. Firstly, yes, I have to put holes in my beautifully repaired bulwarks as well!! Secondly, deep breath, one plank!!!!!! (sorry strake) Does this look right, I spent a while making sure there is no lateral bending. So, what next?
  8. Thanks for that Dom, oh and by the way, thanks also for the tip about using map pins. Brilliant! Just need to get some now. What I will do when I get there is put on just one plank - which might be a control strake at the top. Take a pic and see what you say after that. OK? My hawse pipe/s (thanks again) are not metal on mine. Oh no, I have to carve them and drill them all by myself! And eventually feed the rope through the insy little holes I made in the decks to the bottom of the boat where I suppose I am expected to curl them up to look neat and if someone on board put them there! Just a little rant, I am enjoying it really!
  9. Hello all and thanks for the posts. I had already downloaded the link you gave Dom and read it several times. My problem is that I still don't really understand it all. It's like maths to me and I never was an good at those. I am going to risk doing it instruction way although starting at the top as you suggested. If I make a complete ******** of it perhaps I will be able to improve with the second go. Sorry I have no idea what progressive offset is either. Sounds like a disease to me! For the filler I used 5mm x 50mm thick balsa sheet. Put it in the gaps in vertical layers, used a bit of white glue just to hold it in place and together then, went outside and attacked it with sandpaper down to the level of the fairing that I had already done. The only reason I had time for launch (!!) was because I was waiting for the balsa. I don't know what a hawse pipe is either so I am not a lot of use. So, a bit more filling and sanding before the inevitable. The first planking layer if anyone is interested is 2 x 5 ml lime wood which so far seems nice and difficult to bend!! It is really quite tough stuff. That is partly why I will only go to the first bulkhead as I don't think wood that thick will bend that far. I wonder if I should do that at the stern as well? Any thoughts? Oh the bow bulwark was in two pieces before I made it three and they were supposed to meet in the middle. Once fitted I had to trim the bit below deckline in order to fit in the supplied balsa filler for the bow. Perhaps that's what the disease is!
  10. Do you know I really do like you guys you are so kind. And yes, I am going to be a complete wimp and plank according to the pathetically negligent and utterly useless instructions! By the way, I will do oars and mast for the launch when I know how much wood I have left. Unlike Fifthace boat mine only gets 2 oars according to the instructions but I want the whole set!!!
  11. Hi all, I have just spent 3 days trying to make the Bounty launch with virtually no instructions. I have done my best by looking at other logs and plans so please don't be too judgemental. My filling balsa has arrived!! I have put some in and nearly finished the sanding so I am now running out of excuses for not starting the planking. I am just so scared I can see loads of lack of sleep worrying about it but, seeing as how we are supposed to admit to both our successes and mistakes I will keep you updated. Here is my work to date!!
  12. I agree with the other guys. I find CA very useful for a 'quick fix' but carpenters glue gives a much better bond. Don't be afraid to thin it down a bit, I find that helps avoid spread when joints are tight. The other beauty of white glue is that it dries translucent. Dom is right, the decks don't quite go to the edges of the bulkheads but I found I needed that space for the fairing. Your work looks really good to me AL. I had some warp problems but not as bad as yours.
  13. HI, no I don't use a little saw, just an exacto or Stanley knife. I checked the mast as well and agree with you completely not that I have any personal experience of sailing at all. I have sent you a PM as well as this post for the matters we have been discussing. Don't give up - together we can work wonders with these kits - whatever we decide to call them!!!
  14. Somehow I just know you are going to hate me but, I just cut my planks by hand using a cutting board with a grid. The first one I cut I use for the measure of all the rest to obtain consistency. I'll bet you wish like me that Dominic hadn't mentioned the slope on the masts. It could be HIS kit is wrong, but I rather doubt it. I am not quite sure what you mean about your mast twisting. As and when I get to actually putting mine in properly believe me, they wouldn't dare move or I would threaten them with the open fire!! Anyway, thank you very much for the compliments. At least your good lady has a polite name for your boat. I have a couple in mind for mine but certainly not for public viewing!! Onwards!!!
  15. Wow, a few questions to answer there. Firstly, I did find your message after all CA, it must have been here all the time so I apologise for my senility!! I haven't had a problem with the masts, they sit just right. Looking from the front they are straight except maybe for a wee bit of warp on the rear mast which does indeed slope very slightly backwards when viewing from the side. Can't say I notice much slope on the main though. The rear and mizzen (?) masts are indeed round pegs in square holes, the main required drilling the seating for if that makes sense. My technique for the fairing was just a longish sanding block and sandpaper for the main hull and a smaller block for the bow and transom. I did use a small file a bit on the transom end formers. I didn't use a dremel as I find it a bit vicious though I might with the planking. Once I had all the decks on the hull was quite rigid and stood up to my sanding abuse!! Bare in mind that the bow section on my kit is balsa blocks which are fitted and shaped after the first planking. I just hope my fairing so far is OK, time will tell. It does occur to me CA that looking at you photos the two halves of your deck do not appear to be square. Is that me or because of your warping problems? I can't believe that you drilled all those holes for imitation nails, I found it quite hard enough with a pencil. For the deck planking I just put white glue on the ply only and then the planks. Unfortunately I have found that the veneer wood for the planks does vary quite a bit in width so you can't always rely on the sitting just right beside each other. Still, it all adds to challenge I guess!
  16. Hi there, looking at your pictures I notice a number of differences. Yours has far more formers at the stern and bow ends than mine, the central portion of the internal hull is planked, I can't see a wheelhouse on yours etc. I know the differences are minor. Didn't you say yours was single planked as well? In case anyone was looking I did give the title to my build out wrong. It should have been Bounty by Mike Dowling Don't know if that made it difficult to find if so apologies.
  17. Thanks Bindy, nice to hear from you again and no shihawk I haven't started yet. I am waiting for some balsa to do a bit of bulkhead filling before I start!
  18. I didn't get a chance to soak anything - it broke just cutting it out!
  19. No we don't have a home bargains! Too far North I guess but I will keep an eye open for your magic glue.
  20. Thanks for that matey!! I wonder if the oozing PVA helps with the overall effect? I just get so fed up with sticking myself to the model with CA!!!
  21. Hey CF, did you like my repair? I have balsa on order already but what on earth is a bull head, and don't tell me it's something on the end of a male cow!!!
  22. Hi again, my kit is certainly quite large and actually very different in construction from Ulises Victoria kit. Mine, unfortunately for me with the planking skills of a turkey (!!!) is double planked as well.
  23. I should have said that I have done several OcCre kits, non boat, and found their products pretty good. I did complete their Mississippi paddle steamer which was great and turned out to be a really impessive model.
  24. Hello there, I am actually building the OcCre Bounty at the moment and have a build log in progress. No sure how to a link but I listed it as OcCre Bounty by Mike Dowling. Hope this helps.
  25. Hi and thanks so much for post and the compliments. Re the planking, when I have cut the little beasts to length I run down both sides with pencil holding 10 - 12 at a time. I have always stuck them on with white (PVA) glue literally one at a time. I know it's a bit lengthy and boring but I like the result. Again I just use pencil to simulate the nailing and when done I give the whole lot 2 coats of good old dope!! Re the fairing. Can you have another look at my pics for me as my concern is that at the transom end particularly I think I still have it far too thick on the false keel especially by the time it is planked. I am also not sure that there should be gaps between the deck and the planking. I realise that normally this wouldn't show but with the monster having one 'open' side to the hull it might. Maybe I am just being too fussy? Yes the bulwark was ghastly ply, hence the snap but I did manage to bend it very carefully with the help of some tape to hold the break. Once I had bent the lining strips the glue for them solved my problem. Yes the outside will be veneered in the end and I don't think it will show at all.
