HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
ChrisLBren
Everything posted by ChrisLBren
  1. Wow amazing work G. I admire the work you are able to achieve at this small scale. I am looking forward to following your progress Chris
  2. Good luck Andreas ! I had a very tough time with these on my La Renommee build and yours has the additional complication of the spacers to address. I am sure you will get it done beautifully ! Chris
  3. These are all great ideas - thank you so much - my construction site is built at the waterline so I have a reference point here. That contour gauge is another great idea I can use when I get to planking the wales next year and I need to get the right bend at the bow.
  4. Hey Group, Just curious what most of you use to take accurate measurements for deck clamps etc on the inside of a hull. Thanks Chris
  5. Quick update - keelson is added. Next up interior planking of the hold.
  6. Looks like a toy to me - thats one of the reasons I exchanged the Proxxon MF70 for the TAIG Mill. I wanted something sturdy and accurate. I supposed it depends on what sort of work you will be doing on it
  7. I bought the 2019 ER. It has the more powerful motor and longer bed
  8. Wow KG - tremendous work ! I am thinking about buying a TAIG lathe. I love my TAIG mill and want to add their lathe to my collection. This will be my first lathe - which lathe did you buy and what accessories ? I will need it for cannon, capstans and for other small parts for my La Renommee build. Thanks, Chris
  9. Have a look at TAIG lathes as well. I do not own one but am very happy with their mill and will be purchasing one in the near future.
  10. Thanks for the kind words - can't recommend learning to sharpen and use scrapers enough - they truly are a game changer.
  11. After two weeks of hard work - here are the results. Learning to sharpen and using the card scrapers proved invaluable as this hull was very tricky to shape with its tumblehome. I did use a proxxon angle grinder very sparingly for a few high spots - not recommended for the faint of heart.
  12. My vote is HMS Prince - I know you had a design on this one a few years back. It would be a huge seller for those who like 17th Century ships
  13. Congrats Willi - really nice work. The carvings look amazing as does the ship. Chris
  14. Thanks Brad - I also bought a tool that arrives today that a French Modeler uses successful to aide in this process along with my scrapers. I will post some photos here once it arrives.
  15. Not at all Mark ! Druxey I did do a bit of pre fairing on both bow and stern but there's still an enormous time consuming job ahead of me. With this hulls extreme tumblehome it makes things even more tricky. I really want to try to use my gooseneck scraper to do a lot of the heavy lifting here - I dont have a ton of experience with this tool but the finish looks better than sanding and with less dust.
  16. Thanks J - I build almost exclusively in pear. On this one there will be some boxwood trim and carvings and black hornbeam for wales etc
  17. The crossbeams are removed to access the interior for framing. Lots of sandpaper and elbow grease ahead of me... I did make a correction to the fashion pieces at the stern, they are now aligned properly.
  18. Thanks for the likes gentlemen ! And appreciate your comments Chuck and Druxey - as you both know from past posts this has been a goal of mine for quite some time to build scratch build a fully framed model. There's still a ton of work ahead of me including next up - fairing the hull, interior first - which is always a "pleasure"
  19. Update after 8 months of work - all frames are installed and the stern is coming together !
  20. Thanks Druxey ! I have paused the installation of frames at 49 and turn my attention to the wing transom and transom frames. I need room to work with these tricky components.
  21. Thanks guys - this one truly is a labor of love as I have been enamored of this frigate and her lines for quite awhile. This is also my first fully framed build that has progressed this far. As far as frame construction I simply cut the patterns, glue them onto a pear blank in this case 4.65mm thick and cut out the parts with a margin of 1mm with the exception of the joint line which is right on it using my disc sander. I place one of the patterns on a glass sheet and glue the first layer of parts at the joints and follow it by the laminating the second layer on top paying close attention that the joint lines are perfect and aligned. Then another plate of glass is placed on top for 24 hours while it dries. The finished frame is then cleaned up with an oscillating sander. As I continue to install frames I am getting a reject here or there so I will take photos next time I have to remake one.
  22. Installation continues thru frame 32 notice the frames reverse at frame 30.
