Everything posted by ChrisLBren
Plugging away at the hawse timbers - here they are after a few attempts. Pencil marks are there for waterline reference. I believe I need to install frame 1 first and then hope they will fit the keel and frame 1 after some adjustments - otherwise do them over yet again ! I am on the fence with nailing the frames with bolts simulated with 22 gauge square brass wire which is the most common way to do it. I'm just not sure if I like the appearance. I have still not decided whether or not the hull will have openings as the lines of this ship are so beautiful I may want to leave the frames intact which certainly is one reason not to bother with the bolts. I could change my mind though. Any opinions are welcome.
Sure Greg, I took a piece of 7mm by 8mm (same dimension as my keel) piece of pear and milled the horizontal notches on top - then flipped it to each side to complete the corresponding notches. Lastly I used a chisel to i finish the notches where they rise above the cut line (Cut line being the bottom of the side notches that sits above the keel proper) Then I severed the top piece using my Byrnes table saw. Actually one of the easier operations so far on this build....
Here's a simple yet brilliant idea - a frame calibrated ruler. The applications including the creation of a construction site are many. Take the lines off the frame profile plan and apply it to a yard stick using double sided tape. I borrowed this one off a French site I have been referencing for my build.
L'Amarante by marsalv - 1:36 - POF
ChrisLBren replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
It does - thank you V !!!! -
Looks really nice ! Question - it does not look like you simulate caulking on your models or if so its very subtle ? -
Thanks guys - I like the Hornbeam a lot so far. It cuts easily and glues well. Also it carves nicely - harder edge to it than Pear or Box. Many of the Eastern European modelers swear by it as a replacement for ebony. As far as bending with heat - I will let you know once I get to the wales. That's probably months away - so far I've broken down and rebuilt more assemblies than I care to admit ! That stem was probably version three. My mill went astray this AM while cutting the rabbet. So I took it apart with my friend Iso Alcohol and will reassemble it tomorrow with a new forefoot. I am very happy the upper part of the stem consisting of black hornbeam was not yet glued to the lower half.
I Have an Itch to Scratch
ChrisLBren replied to SaltyScot's topic in Modeling tools and Workshop Equipment
This is the scroll saw you want - and buy the optional stand. https://www.homedepot.com/pep/DEWALT-20-in-Variable-Speed-Scroll-Saw-DW788/203070202?mtc=SHOPPING-BF-CDP-BNG-D25P-025_009_PORTABLE_POWER-NA-NA-NA-PLALIA-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_2023&cm_mmc=SHOPPING-BF-CDP-BNG-D25P-025_009_PORTABLE_POWER-NA-NA-NA-PLALIA-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_2023-19672073971-145268702359-2274863535266&msclkid=3c2019a6f0a416cca20d718582c146c2&gclid=3c2019a6f0a416cca20d718582c146c2&gclsrc=3p.ds&gad_source=7 Having a good scroll saw for scratch building is vital. The other tools I use the most are Jim Byrnes Thickness Sander/Disc Sander, Oscillating Spindle Sander and TAIG Mill
