Marcus.K.
Everything posted by Marcus.K.
  1. Gentlemen, still digging into this tiny little bit of detail .. but recently found more evidence for the existance of a "visible" thickness change of the wales vs. the planking - even if there is "thick stuff" beside the wales - planks which are thicker than normal hull planks: This is from David Steels "The elements and practice of naval architecture" - the 1822 version .. and it seems the wales are noteable thicker - I guess the corner might be a bit "chamfered" .. but the edge and the thickness-change are really notable. There would be a "line" .. And - I have to appolgize - there is something I did not see before .. Cornè´s side view of USS Constitution in 1803 shows clearly a top and a bottom "edge" of were we believe the wales have to be: Can you see the color shift? .. This seems to be the wales in 1803 on the ship.
  2. Thanks Gentlemen !! I fully agree being careful with compareing the orginial design with results impacted by later repairs and renovation. Constitution and Victory both have a VERY long history - and since they are wooden ships, most of the timbers have been replaced - often much more than only one time. The good thing in case of Old Ironsides: we have this Humphrey Specifictions written in June 1794 - which at least describe his plan in that year - and which provides the width and thickness of the used timbers. Unfortunatly not position nore final shape (as this dimensions most likely were the "midship" dimensions where planks are widest) and not providing any information about the tapering vs. bow and stern section. And of course also no information about the edge preparation of the designs. ... This seems to be "a copy" which might be the basis for the text in the "American State Papers - naval affairs Vol. I" which often is used as reference. Martin - who collected so many information concering Old Ironsides - unfortunatly is not very precise with his sources - especially in his books. I got a copy of the "a close up" in which carefully lists his sources. His statements on Page 70 ff in "Building a Legend" make from principle perfect sense - but I did not see any source providing that thickness change - nor any details concering the way the thicknes change was done - especially on the main wales. So especially these edges were the concern of our discussion in @The Bitter End´s building log. We were wondering whether the edges are smoothened - to prevent rotten wood at the exposed edges - and "in order to carry the water out of the seam" - a very important issue. Any "unchamfered" edge in the ships planking (where thickness of planks changed) might generate a tiny "plateau". And especially if the ship is sailing close to the wind the steps in the planking on windward side would even generate tiny "pockets" in which the water would be able to stay and work it´s way into the caulking. I used one of Lords section cuts as starting point - just to illustrate the position. If the top edges of the wale would not be chamfered or smothened ... it would look like this, right? And the result on sea would be that one: Water might be trapped and has a lot of time to make it´s way into the caulking or work its way into the wood allowing the planks to start rotting. Chamfered the situation would change: A chamfer done at the wale´s edges must on one side come as close to the next thinner plank as possible - and must be wide enough to avoid any pocket under heeling. It wasn´t a simple 45° chamfer of the edge. It was at least a perfect reshape of the timbers edge to fulfill that task. Even a complete "smoothened" upper wale plank is possible. THIS is the question we try to clearify - do we know from other ships how the edges of the main wales were shaped? I guess if we look into models the builders might not have shown that chamfer - as it is a) hard to produce in a pleasant way (having the chamfer being constant over the lenght) and b) it might be just too small to try to represent it. @Force9 you sure are right concerning John Lord´s reconstruction - which is impacted a lot by his given timeline and budget. But what chance did he have? .. At least his two section cuts from 1926 showing his research seem to me to be not that bad! He tried to follow Humphreys written specs - and he obviously studied paintings (Cornè and others) and "old models" (Hull Modell?) - and he did not have internet ! But I agree: one must be careful in studiing his results. .. and that´s what this posts is about 😄 By the way: Haiko @The Bitter End was pointing on the fact that even in my examples of Hartt Shipyard build ships like USS Enterprize and Boston one might be able to see a tiny edge indicating the wales ... Do you see that tiny bright line below the gun streak? If you look into the engraving you even think to see a line in the midship area .. One would need to see the original engraving to study that effect better ..
  3. Let me dig deeper in this topic: @Mark P was stating: Is that really true for all ships? @The Bitter End found in his building log USS Constitution by the Bitter End - Wales reason to doubt that. Were the wales, which consisted of thicker planks than the regular ones, left with sharp edges at their margins – or were the transitions to the thinner planks worked in such a way that no visible edge remained? We found that the Isaac Hull Model does not show the wales at all. Here in this photo - taken by @Force9 - we can see no edge indicating the contours of wales. John Lord - in his reconstruction of Old Ironsides between 1926 and 1931 produced several - at least - 3 drawings with 4 different section cuts, in which he showed different approaches: In his Feb. 1926 drawing #35208 he shows what his research of the Joshua Humphreys papers and other sources seem to have indicated: The 6 thick planks of wales are supported by not as thick (but thicker than the planks) 5 planks "black strakes" on top and 4 planks "thick stuff" below the main wales. The dimensions for sure were provided in Humphreys list of material. Of course - what nobody can know from the written specification of the materials main dimension of Humphreys list : did the shipwights smoothen the edges - or did they keep the edges "sharp" or with a certain chamfer - so that the thick strakes or the main wales would be notable as being something other than the classical planks? In his Jan. 1926 drawing #34535 he represents on left side the ship as he found it - most likely done in the earlier 1906 resoration - while the right side shows what he by then found after "considerable researche" including "old models", "drawings", "paintings" ... The 1906 / 1926 Ship seems to have the edges of thicker planks smoothened - so that at observation no one would notice which of the planks are wales, which are planks. It would look like this photo: this is the 1926 ship - at the beginning of Lord´s restoration process - as he "found" it (like in left side of the drawing #34535). On right side of that drawing it now seems that only the top edge of the wales have a sharp edge. If we look at Lords final drawing #24472 done in June 1931 we can see that now even the top edge of the wales are not visible anymore - just as the ship was done in 1906: O.k. .. all those drawings were done in the late 1920s .. ca. 130 years after the ship was launched. How was it done in those days around 1800 ? Let´s see what Maestro Felice Cornè had to show in 1803 - "Frigate Constitution": is there a fine line below the ochre gun strake in the already black area.. just above air vents of the berth deck? ... Hm... Maybe even a tiny indication of a line in about where the wales lower edge would be?? Or do I just wish to see that ..?? Let´s check the sistership: US Frigate President: Antoine Roux - a in many details precise observer of Mediterian Sea vessels painted several times USS President - in around 1803. No prominent wales visible, right? If we look at this beautiful old bones model of US Frigate Chesapeake - done 200 years ago by prisoners of war - this model is in Internationales Maritimes Museum Hamburg. The model builders were experts, sailors knowing those ships in detail. It might have been done by sailors of the USS Chesapeake after being captured in 1813. Would they be mistaken when showing the wales having very sharp edges? You can see on top and on bottom the sharp thickness increase for the wales. Also from british admirality models of that times we also know that often the wales were prominent and clearly distiguisable from classical planks. .. On the other hand: those edges would always be endangered to be damaged, if the ship was struck by harder objects in the water like boats, loads, flotsam, etc.. And those damaged areas would be the starting point of rotten timber .. making repairs essential. So there are pro´s and con´s for prominent wales. It might be that the wales just in models were prominent as they were a very important feature for the admirality or experts to really see the ships "anti-hoggin-stiffneners".. it might be that the wales were prominent in real ships too Maybe some shipwrights just did not smoothen the edges of the thicker wales as this is effort which was not payed - seemed not needed by some? Maybe other ship yards did smoothen the edges as the lower edge would cause resitance and friction in the water and both - lower and upper edge would be senstive for damage. By smoothening they durablity of the planking would be improved - an expensive work - but providing more robustness. maybe just some artists (modelist, paintes, engravers) just did not show this feature? Is it possible that both options existed in parallel? Some ships had prominent edges?.. some had smoothened wales? Maybe it depends not only on the nation but the shipyard what was the preferred design?? So we started trying to find if George Claghorn or the Hartt Shipyard had their own "habit". George Claghorn, the assigned shipbuilder for USS Constitution, was chosen as he was building "big" ships before. We found that a waler - Rebecca - a ship of 175 tons and the first waler to pass Cape Horn and a merchant ship named Barclay with 200 tons have been build by Claghorn before USS Constitution. Non after the big frigate. Unfortunatly no visual description of both ships seem to exist today. A dead end for now. For the Hartt Shipyard there is a bit of visual evidence: This is USS Michigan (https://en.wikipedia.org/wiki/USS_Michigan_(1843)) build some years after Constitution. Its hard to really see - but at least we can not identify the wales .. very little evidence for anything, I agree ! .. a poor picture ... There are two engravings by the french artist Baugean - who was a precise documenter of ships in this age - showing ships build in Hartt´s shipyard: USS Enterprize .. a very smooth ships hull, right? But I agree: here too the simplification by the artist or even the poor representation of the digital photo might just not show the wales. What about this one? Source: https://en.wikipedia.org/wiki/USS_Boston_(1799)# USS Boston 1799 - also build in Hartts shipyard in Boston. Here the artist / the representation even shows vertical lines to show the shape of the hull - and no step is visible at all. And finally even a photo again! Source: https://en.wikipedia.org/wiki/USS_Independence_(1814)# This is USS Independance as a hulk in the 1890s - and if you investigate the area close to the bow - in between that vertical toilet effluent pipe and the start of that 2nd layer of "overplanking" of the ships sides you recognize the orginal planks of the original hull of the ship - and again: no step is visible, no sharp edge. And of course: the photo is not very sharp - and we don´t know whether the planking is still the original one. The ship had been razeed years ago - and for sure had to go through repairs .. who knows how old those planks are. Summarized: do those few examples provide real evidence that at Hartt´s shipyard it was custom to smoothen the wales? .. a "thin ice" assertion - maybe, maybe not - but a possibility. If we add the Cornè-painting of 1803 .. and if we assume that this tiny line SHOWs an edge, ... well .. all that is interesting - but does not really solve the mystery, right? Now to you, shipmates, comrads, experts, sirs, ladies and captains .. Does anyone of you have better evidence of what was done in about 1800 in Boston´s Shipyard - or in the US in general - or .. in other nations? Is there any known logic? Were edges always prominent? Was that sometimes the case - and sometimes not? .. if so, why and where? Did any authority in age-of-sail describe this feature in detail?
  4. Hey Jon, Gentlemen, Ladies (still hope there are some reading and participating in this) thanks for the correction. I have to admit that my typos are based on my lack of precision and concentration. I am sorry for that. I should be much more careful when writing in public spaces. I know mistakes like that are often seen as lack of respect ( and I assure : that isn´t the issue here ! ) - and I wished my statement would not sound that much as a cheap excuse. But this was and still is my main issue: not being patient enough - not being precise enough. That too prevents me from doing modeling myself. I just can not be as good, as I want to be ! I am never satisfied with my result ! But the one thing I believed to have translated correct is the "diagonal riders" which Humphreys intended to get - and got at least in Constitution. Diagonal stiffeners were known before - and later. Beside other inventiones and improvements (later Sir) Robert Sepping was using and improved them until he later even used iron knees to increase the stiffness and robustness of wooden ships for the Royal Navy: see here: "longitudinal Binders & Iron Riders https://warhistory.org/@msw/article/seppings-truss-system But in general - to come back to Haiko´s need - it is hard to guestimate the right detail design for Old Ironsides in its earlier appearance. As we have only the verbal descriptions and main dimensions of most main components (and it is very likely that those dimensions were the "delivery dimensions") in Humphreys 1794 "specifications" and only rare and not very precise paintings in her earlier years. As Haiko pointed out already: the 1803 and 1804-05 Cornè paintings are too tiny to show a detail like edges on wales. The 1803 Roux paintings do not show distinguisalbe thicker planks. The earliest serious source is the Isaac Hull model which the crew did build for their beloved captain in 1812. And beside some odd details it turns out that someone tried hard to represent a lot of tiny little details which may not be too important - but caused for sure efforts for the builders. That they did NOT represent wales or black streaks with edges might have to tell something. Or course there is still a certain uncertainty - and I guess there still will be one for a very long time. I am not sure - as Royal or any other Navy is not my field - but I would not be surprised if the represenation of wales with "sharp egdes" in British Admirality Models or even drawings might be a way to point on an important feature - which in real life would be smoothened. As they were an important feature to stablize the framing and protect the hull I would not be surprised if Admirality wanted to be able to exactly see their position and shape. I think we are all used to "see" them .. and this may be misleading due to my above mentioned arguments.
  5. GREAT ! THANKS !!! Would you agree the note says: So .. does that help us? @JSGerson What´s the source of that black-white-copy? Which book is it from, do you know? THANKS for this!
  6. Oh, Gentlemen, pls. be very careful with Karl-Heinz Marquardt´s Constitution. Marquardt did a lot of very interesting and excellent research in many fields of ancient sailing vessels. His AotS Constitution book is unfortunatly not a highlight - and I have the impression that its - unfortunatly - perfect presentation and the huge impact of the author´s name did damage a lot to the general view on the ship and caused a lot of errors to so many good model builders. Let me pls. try to help here. First of all: there is of course no doubt that the ship had wales - as I understood Haiko he is looking for how to shape the upper and lower edge of them: an invisible transition between the heavy wales and the thinner planking – achieved by gradually diminishing the thickness at the edges – or a sharp transition with a distinct arris or a chamfer. Second: that section cuts you showed, Haiko, are from one drawing - in which - in the gun deck level - two texts explain the content of each half: Left side is "Port side - present construction and arrangement" - so this is what Lord found in 1925-26 from the 1906 renovation. Right side of the drawing: "Starboard side - proposed re-construction" .. Above the header of that drawing #34535 is a text explaining that the drawing is based on "considerable research" and even if the text on gun deck says "Proposed reconstruction" we need to be careful - as the final result differed. These are the two half section cuts to showed in your post, Haiko. And below you find the text right of that section cuts - above the drawings header. This next photo done in 1927 shows what Lord was finding from the 1906 renovation: I believe we can not identify for sure which planks were the thicker wales - and which were just planks, can you? But there is another drawing - #35208 - in which Lord seems to represent the "from Specifications .. Joshua Humphrey "as the note close to Lords signiture explains. Unfortunatly I can not read that text above the header. Does anyone of you have a copy of that drawing #35208 - with a readable "note" above the header? This here is a copy of that drawing #35208 as it is represented in Magoun´s "Old Ironsides and other historic ships" - unfortunatly without that note and the header. And then there is this last section cut of the Lord Restaurtion (I know about) #24472 - done in 1931 "as finished" - which represents what we would find in 1931 .. I did not (yet) find any represenation of the ship in which the wales would look like the britsh "puzzle" with these short "pentagon"-shaped pieces as Marquardt shows in his unfortunatly beautiful book. It is much more likely that the US Frigates had - from beginning until today - more simple but robust and long planks as wales as there never was lack of long wooden planks in the US - in contrary to their British cousins - which had to deal with shortage of wood in the 1800s. Looking through all the representation I collected of US Frigate Constitution or her sister ships I never could identify an "edge" of the wales. Either it was that tiny that it was not obvious enough - or it just wasn´t existing. Here an example for 1871: The artist did show all kind of ugly things - like that ****-ramp on the bow or the tiny air vent in the quarter gallery. Many strange and ugly details. Would he miss distiguisable wales? Or here: in 1857: No wales visible - which does not at all mean they were not existing. Just: there is no edge notable. Another approach - from technical point of view: an edge would make no sense - neither on top nor on bottom side of the wales. On bottom side it would just increase friction in the water. On top and on bottom side it also would be endangered to get damaged, while doint what wales have to do: being a bumper for any object floating against the ships hull. And if an edge was damaged, the wood would be in much more danger to start rotting. So high risk. And how to repair? You had to remove a plank out of the hull! What would be the benefit of a sharp edge? .. or even a chamfered edge? Technically it would make no sense to have the wales not smoothened to the planks. Any other feature to protect the hull from impacting objects like fender strakes for the loading or for the action with the boats - or billboards for protecting the hull from the ancres.. Those were added on top of the planks - and were easy to remove if demaged or rotten. In my opinion those planks being the wales were just thicker - but you would not be able to differentiate them - except maybe by a bit wider? - but I don´t see evidence for that either. I would not represent them in the ship as an extra layer or as thicker planks with a distinguishable edge.
  7. Those Close Ups look amazing !! One really struggle: "... is this the ship? ..oh, it´s a model!"
  8. I recently learned the statement: "if you have issues in keeping up doing something, you need to frequently restart restarting." I hate to move! That amount for work and time waisted until you have settled into the new environment. Yes, its an opportunity to get rid of ballast - but no, I believe its not worth it! Getting rid of ballast can be done without moving. ... of course we humans tend to not doing it, right? Good luck with your restart - maybe it helps, if you know: we are eagerly waiting for updates 🙂
  9. As Martin points out: he concluded a single and a double wheel just because on number of payed "men on the wheel" (two in case of single wheel and 4 in case of a double wheel). But that calculation has anyhow a flaw: if one assumes that 2 men would man the single - and 4 man would man the double wheel, we would in fact need 4 men for the single and 8 for the double wheel - right? So that each watch had a full manned wheel. So to conclude for the number of wheels just by the paid helmsmen, we would need the double amount of personel. IF we allow the single wheel be manned by only one dedicated (and paid) person per watch (and being assisted by another "common" sailor) .. why would that not be possible on a double wheel? .. There could have been one dedicated helmsman per watch in the beginning - even on a double wheel - who might have got support by 1 to 3 more common sailors in case of need. Maybe the navy later decided to pay 2 helmsman per watch - just to make sure that there is enough experience at the wheel? But by THAT the NUMBER of helmsmen would not affect the number of wheels themself. To summarize: if we doubt Martins conclusion (number of wheels connected with number of paid helmsmen), we may stick with the assumed double wheel - from beginning. That would be my assumption - until there is more evidence for a single wheel ...
  10. Oh yes, what happened, @Force9? I was reading the post this morning and was again impressed about the details you found in Hull's report and concerning Corne's possible misinterpretion? Unfortunatly I am under pressure at work, come home late, leave early for the office.. I missed answering earlier. Can you please check whats wrong, Evan?
  11. I tried to present you a table with the captains, their nomination as captains and commodores and their birth dates from beginning to about 1815 - and hoped I can manage to make it "sortable" as for example in an excel table. Unfortunatly I am not capable to do so. But even with that table you see that some younger captains where higher in rank depending on the captain or maybe the commordore nomination. That of course might have (and did) cause hurt feelings sometimes 😄 .. those gentlemen usually had a strong will 😉
  12. # Name Born–Died Captain Since Squadron Command (Commodore)? Notes 1 y John Barry 1745–1803 7 Jun 1794 1798 – West Indies Squadron First senior officer of U.S. Navy 2 y William Bainbridge 1774–1833 7 Jan 1801 1815 – Mediterranean Squadron Captured in 1803, returned 1815 3 y Samuel Barron 1765–1810 13 Sep 1798 1804 – Replaced Preble in Mediterranean Ill health ended command early 4 y James Biddle 1783–1848 1814 Not until after 1815 Served on USS Wasp; later Commodore 5 y Isaac Chauncey 1772–1840 1806 1813 – Lake Ontario Squadron Directed Great Lakes ops 6 y Richard Dale 1756–1826 4 Jun 1794 1801 – Short Mediterranean deployment Retired early 7 y Stephen Decatur 1779–1820 9 Apr 1804 1815 – Mediterranean Squadron (post-war) Hero of Tripoli & 1812 8 n Charles Gordon 1781–1860 ca. 1813 No Capt. of USS Congress briefly 9 n Joseph Green ? – ? ? No Commanded privateers & small ships 10 y Isaac Hull 1773–1843 23 Mar 1806 Not until after 1815 Capt. of Constitution, defeated Guerriere 11 y Thomas Macdonough 1783–1825 10 May 1807 1813 – Lake Champlain Flotilla Victory at Battle of Plattsburgh 12 y Richard V. Morris 1768–1815 ~1799 1802 – Mediterranean Squadron Recalled in disgrace 13 n James Lawrence 1781–1813 3 Jun 1810 No Killed on Chesapeake (“Don’t give up the ship!”) 14 n Oliver H. Perry 1785–1819 1813 No (technically flotilla leader) Lake Erie hero 15 y Edward Preble 1761–1807 20 Jul 1798 1803 – Mediterranean Squadron (Tripoli) Highly influential 16 y John Rodgers 1772–1838 2 Sep 1798 1803+ – Several squadrons (Mediterranean, Home) Senior-most officer 1812 17 y James Sever 1761–1845 10 May 1798 c. 1799 – West Indies Retired early 18 y Charles Stewart 1778–1869 22 Apr 1806 Not until after 1815 Capt. of Constitution late in war 19 n Thomas Truxtun 1755–1822 4 Jun 1794 1799 – Caribbean Squadron Famous from Quasi-War 20 n Jacob Jones 1768–1850 3 Jun 1810 No Capt. of Wasp (defeated Frolic)
  13. Gentlemen, thanks for that intersting debate. I had to learn a lot. Its quite fun as answering one question two other interesting aspects pop up and you need to read further, dig deeper, learn more ... If I got it right what I was reading the last days it seems that my understanding that a squadron leader who just met a more senior commodore was forced to pull down his broad pennant and show a "lower seniority" broad pennant was absolutly wrong. You are right @Force9 Evan. There is only one squadron leader. When Barron met Preble and took over command over the Mediterean squadron Preble had to lower his broad pennant and the commission pennant was raised on Constitution instead - while Barron´s broad pennant was still floating on his US Frigate President´s mast top. Barron was now in charge. The different colours of the broad pennants would have been used, only if several squadrons worked together as a fleet - and each squadron would have had its own squadron leader, its own commodore. .. just as the britsh did with their rear-, center- and vanguard-division. In those cases different colored broad pennants would have been presented to each flagships main mast. But that did not happen the early years of the US Navy as there was rarly (never?) a chance to act as a fleet of several squadrons. The US naval strategy and tatics was different - as the young navy never intented in those days to make use of battle ships and fleets. But the idea was having flexible and persuasive squadrons dealing with only minor enimies as privateers, corsairs, pirates or maybe a squadrone of frigates or a single 2nd rated ship of the line. But never with a 1st rate ship of the line or even a fleet of ships of the line. That was not yet the focus of the new navy. Seniority was a tricky thing in those days it seems. Hull was the more senior captain to John Rodgers, although Rodgers was about 1 year older. But Hull was appointed to captain only some months earlier than Rodgers. On the other hand: Rodgers was first in getting a command over a squadron - and by that was in a way the more senior commodore. I guess that was part of the animosities among some of the early "commodores". Hull seemed to have agreed to switch the ships USF President and USF Constitution with Rogers - although he might have had the right to stay on the ship with higher prestige (in those days), the President. But it seems he did accept the change especially having in mind to to preserve harmony and reinforce the bond between the officers. .. maybe .. but there seem to be no written evidence .. maybe he was even happy to be on his old ship of his "Quasi War" and lieutenant times - and maybe he was looking forwart to meet some of his old comrades - helping him to improve the ships performance and make it a much better one compared to the days of Samuel Nicholson and Silas Talbot.
  14. This is what I found in one of my most liked sources: Cmdr. Tyrone Martins collection. Its in his "lucky bag" section of his "The Captains Clerk" homepage. That is at least the order of colors defined in 1817 and 1818 as it seems. But of course it is not clear how that may have used in previous years.. As I was writing: the habits were still developing and not yet fixed ..
  15. I am of course not sure as I never were able to compare PE bars with the ones you showed here, but I believe that the round shape of these bars is a better looking solution than usually not round etched ones. Even if spacing might be worse. I am curious for the painted result and it would be interesting to see a close up comparison of both variants. In any way: impressive and beautiful!
  16. Ah - that´s interesting !! Sure!! I did not realize this salute process! THANKS @Chapman
  17. 1. Overview In the early years of the U.S. Navy, there were no formally codified regulations for identifying naval vessels. The processes and traditions of the fledgling service were still in the making. Standardization was not yet the primary concern—rather, the focus lay on establishing procedures and organizational structures. Undoubtedly, there existed unwritten customs rooted in British naval practice and those of other maritime nations, though concrete documentation is scarce. Nevertheless, some sense of what was common practice can be gleaned from period illustrations—particularly the many works of American maritime painter Felice Cornè, among others—as well as from occasional primary sources, such as a 1803 inventory recorded by Midshipman Henry Wadsworth aboard the U.S. frigate New York (Langley, 2003–2004). Wadsworth records the following items: · 4 american Ensigns · 4 commission pennants and 1 Jack · 2 american Burgees · 3 american Broad Pendants The Ensign was the national flag, typically flown from the flagstaff at the stern. In battle, it was often hoisted on additional masts or spars to ensure it always remained visible — since lowering the flag during combat was interpreted as a sign of surrender. To avoid any such misunderstanding in the event the main flagstaff was shot away, it was both common and critically important to display at least one additional, redundant flag. The Jack was a smaller flag used to indicate a ship’s nationality. It was flown at the bow—typically from a short staff mounted on the bowsprit or foredeck, known as the ‘jackstaff’—but only while the ship was at anchor or moored.. Commission Pennants (historically also spelled 'pendants') are long, narrow, triangular flags that were to be flown from the highest mast of every officially commissioned warship. Their purpose was to distinguish naval vessels from merchant shipping. American Burgees were smaller flags bearing national symbols—such as the ‘Don’t Tread on Me’ flag or various designs featuring stars and/or stripes. In modern usage, burgees are typically triangular pennants, most commonly recognized in the sailing world as flags denoting membership in a yacht club. Broad Pennants — also referred to as command pennants — were used to indicate the rank of a squadron commander aboard a particular vessel. Importantly, when a squadron leader or higher authority was present on board, the broad pennant would replace the long, narrow commissioning pennant at the masthead. 2. The Ensign In its early years, the American national flag was not yet standardized as it is today. Since the United States was still in a formative and expansionist phase, and new territories continued to join the Union, both the number and the arrangement of stars and stripes on the flag varied over time. What remained consistent, however, was the general layout: a blue canton (the upper hoist-side quarter) bearing white stars, and horizontal red and white stripes—varying in number—filling the remaining three quarters of the flag. In those early years, as is still the case today, each state was represented by a star in the canton. However, at the time, each state was also symbolized by a stripe—distributed across the rest of the flag. Only in 1818 was the number of stripes officially limited to thirteen, in honor of the original thirteen founding states, as it had become increasingly difficult to distinguish the red and white colors clearly when the number of stripes exceeded fifteen. Above section illustrates that, at least in 1804/05, ships in active service could still be seen flying different versions of the national ensign side by side. With the admission of Vermont and Kentucky, the flag at that time displayed 15 stars and 15 stripes. In the following section, we will take a closer look at these flags: In this view the U.S. frigate Constitution displays the classic '15-state flag' variant, with the 15 stars arranged in three rows of five. To the left of USF Constitution the U.S. schooner Enterprise is shown flying a different variant, the so-called 'Maryland pattern,' which typically featured white border stripes and 14 stars arranged in a circle with one central star. However, it seems that Felice Cornè simplified the design somewhat, as we can only count 12 stars and 14 stripes. While the missing stars might be explained by a possible fold in the flag, the complete absence of the lower white stripe appears rather peculiar. That Cornè was capable of greater precision becomes evident in the following illustration, which is in fact even older. Here in above picture, we can clearly see all 15 stars and 15 stripes—just as they appear on the original shown in the next photo. However, even at this stage, it becomes apparent that having 15 stripes makes it increasingly difficult to distinguish them individually from a distance, and the red and white begin to blur into a washed-out pink hue. This photo shows an original national flag in the Maryland pattern: 14 stars arranged in a circle around a central 15th star—and 15 red and white stripes, with a white stripe at both the top and bottom. Felice Cornè’s well-known side view of the U.S. frigate Constitution from 1803, the earliest known depiction of the ship, shows a version with apparently 17 stars. This may indicate Ohio and Tennessee, which had already joined the Union at that time but were not yet officially represented on the flag. The number of stripes is somewhat puzzling again—there are only 16—and the top stripe is white while the bottom one is red. Cornè’s effort to depict such a large number of stars can certainly be seen as an attempt at accuracy. Had he been merely imprecise, the more logical outcome would have been to show fewer stars rather than striving to cram more stars into such a small space! It was not until 1818 that it was legally mandated: one star per state, and 13 stripes representing the founding states. This rule remains in effect to this day. However, this also shows that flags in the early years of the new nation still allowed for certain liberties—a topic that alone could easily fill an entire book. 3. The Commissioning Pennant British, American (and likely other nations’) warships flew a long, narrow, triangular pennant at their main mast—the so-called commissioning pennant—as a symbol of their active (military) service status. The American version displayed at the hoist a blue field with vertical red and white stripes. Today it bears seven stars - in earlier times, thirteen, symbolizing the founding states. The origin of this flag and tradition can be traced back to ancient Egypt and has been in continuous use through the Middle Ages to the present day. The commissioning pennant was only replaced by the flag of an admiral or high-ranking civilian official when such a person was aboard. However, it was both possible and customary to fly another flag beneath the commissioning pennant—for example, as a salute or for signaling purposes. This image possibly depicts the early Old Ironsides. However, Cornè may have intended it merely as a ‘typical’ frigate, since the entire painting centers on the theme of the East India Marine Hall, and the frigate serves only as the central focal point. What can be observed, however, is that beneath the long commissioning pennant another rectangular flag is flown. Could this be a salute to the honorable East India Marine Society? 4. The Jack The so-called 'Jack' is also a national flag, displayed only when the ship is at anchor or moored, flown on a short staff at the bow. This allowed for identification of the ship’s nationality when approached from the bow. Such identification was often necessary when the ship was at anchor and the stern had turned into the wind, rendering the ensign at the stern invisible. Typically, the Jack is a simplified version of the national flag, displaying only the ‘canton’ — that is, the upper left field of the U.S. national flag: a blue field adorned with the appropriate number of stars. The so-called "First Navy Jack" featured the rattlesnake and stripes motif, inspired by the 1775 Continental Army flag—a symbol of resistance and independence from the British Crown. However, this flag was only officially used between 1975 and 1976 (in preparation for the Bicentennial celebrations) and again from 2002 to 2019. There is no evidence that it was flown during the early years of the still young U.S. Navy. 5. American Burgees There is little information available today about the "American Burgees." Burgees—typically smaller, triangular flags—have historically served and continue to serve as identifiers and communication signals between vessels. In addition to the ensign, these “American burgees” were evidently intended to mark a ship as distinctly American. Flags bearing inscriptions such as “Don’t give up the ship” might also be understood as burgees—a powerful symbol directed at both friend and foe. Captain Perry referenced the last words of his friend, Captain James Lawrence, during Lawrence’s engagement aboard the USS Chesapeake against HMS Shannon in late May 1813, and successfully used the motto to rally his own squadron during the Battle of Lake Erie in late summer 1813. This representation again depicts national flags on the foremast and mizzenmast of the USS Constitution, as Cornè portrayed them in one of his paintings of the battle against HMS Guerriere. Once more, it is evident that the arrangement of stars in the blue field had not yet been standardized, and different patterns could even be flown simultaneously on the same ship. 6. The Broad Pennant Up until shortly before the Civil War, "Captain" was the highest permanent rank in the U.S. Navy. Captains commanding a squadron were honorarily titled "Commodore" and flew a broad pennant. These pennants came in blue, red, or white depending on seniority and displayed stars representing each state: · Blue with white stars for the senior-most commodore · Red with white stars for the second-ranking commodore · White with blue stars for all others Therefore, Wadsworth likely recorded “3 broad pennants” in his midshipman’s logbook. The large U.S. frigates such as the Constitution, United States, and President were the biggest ships in the Navy until the War of 1812 and often served as squadron flagships. With the arrival of a senior (in service) commodore aboard his flagship, it was clearly necessary to adjust one’s own squadron rank by changing the color of the broad pennant. Hence, all three colors were surely needed on board. . Commodore Preble, for example, flew a blue broad pennant with 13 stars—symbolizing the founding states—during his operations off Tripoli in 1804. The shape of this pennant was a wide, truncated triangle. It was only years later that the now-standard swallowtail design became common. Signal flags are also displayed on the mizzenmast in above´s picture. In Cornè’s 1803 depiction, a broad pennant is being hoisted that appears to show the American ensign instead of stars. This again indicates that flag usage in the early U.S. Navy was not yet strictly standardized. 7. Other depictions done by other artists The rigging and flag display of American frigates can, of course, also be observed in other paintings. The already mentioned exquisite French artists lead the way, of course! But other depictions naturally also show the common practices already in use. In the storm, only the broad pennant remains hoisted on the main mast. All other flags were likely taken down for safety. This is a magnificent painting by Antoine Roux that reveals an incredible number of details about the large American frigates. Studying this work — as well as the painting of the President in the harbor of Toulon — comes highly recommended for anyone interested in the American 44-gun frigates. Here, we again see the commissioning pennant and the national ensign at the stern. The jack is not yet hoisted, indicating the ship is not at anchor. A very fine example of the long commissioning pennant, still showing clearly more than the seven stars commonly seen today at its hoist. 8. Conclusion It is important to keep in mind that, in addition to the lack of standardization of flags at the time, there were also inaccuracies in the artists’ depictions. However—despite all criticism regarding precision and the contradictions found, for example, in Cornè’s works—a closer examination reveals remarkable accuracy and attention to detail. Even the apparent contradictions can be explained, and the accusations of “errors” or “simplifications” often seem exaggerated when considering how many intricate details he managed to depict in the tiniest areas of his paintings. Compared to his French contemporaries like Roux or Baugean, Cornè may have lacked a bit of precision. Yet he was capable of rendering minute details and indeed did so. Therefore, when he chose to depict small details deviating from today’s expected “norms,” such as adding a miniature national flag to the broad pennant instead of the often used 13 white stars only, it is unlikely that this was done on a whim. Rather, it can be attributed to the still undefined rules concerning the exact design of official flags. Based on the many beautiful illustrations and some scarce written records, the early national and command flags and their usage can be fairly well reconstructed. As with any historical research, one must carefully study the customs and practices of the era to achieve a more realistic representation of the original. The lack of standardization complicates this somewhat—but nevertheless, certain rules can be identified that allow for an accurate depiction of an early US frigate.
  18. Hey @uss frolick .. you nearly got me 😜 ... That flag seemed really to indicate: "not a warship".. but.. Tonnerre de Brest!!! The photo of that painting was done not very well - as the flags are partly covered by reflections of the flashlight. If you see another representation of that scene - on the book cover of George H. Schwartz´s interesting book, you´ll notice a pennant on top. I guess this indicates: Navy ship in duty - maybe "greeting" the Society with that 2nd flag? See here: A men-o-war ? .. with guns stored inside? I believe to remember having read in Tyrone Martins "a most fortunate ship" that during the early travels of Old Ironsides the guns were stored completly inside - which caused a lot of issues concerning the available space on the gun deck - although the guns were a bit shorter than needed for the battle. Later then the configuration was changed and the gun ports (still not hinged but removeable) got this split which allowed the guns to be stored "outside" while having the ports closed and sealed. That - and the dark shadow Cornè chosed to set the side into - would explain the lack of guns at the ships side. A thesis .. What do you think, Ladies, Gentlemen? also very interesting is that design of the US Flag at the stern. I know there were many different ones during the times - depending on how much states joined the union - and of course the early "finding phase".. but I never saw anyhting like that?
  19. This is the first time I see that last photo - with the stern at the hull - and it´s just incredible !! What a beautiful sight ! I said it before and I have to repeat it here: this cross-hemispherical cooperation is a lot of fun and how you, T.B.E. realized for what I before just had a rough idea was and still is a miracle. I have to state that T.B.E. really had to shorten that explanation about how we found the presented layout. As he mentioned - it was journey for several weeks with a lot of exchange of information, concerns, rethinking, again studiing the sources, even finding new ones (!), rethinking the old interpretation .. Just as an example: T.B.E. did not like the appearance of the white window frames - and while discussing the possible alternatives and their likelyhood we recognized that the 1803 Cornè painting - done before the 1804 Tripolis-paintings showing that stern! - showed red window frames in the galleries. Accidently we stepped over another representation of the ship which - it seems - by now has not been identfied as USS Constitution. And even if it is not Constitution - the similarities are really obvious ! - it at least shows that red windows on a big American frigate are a likely alternative: This is a painting in Peabody Essex Museum in Salem, MA, USA. It was done by Felice Cornè in 1803 - the year he did that famous side view. Even if the ship was just intended as a "typical" American frigate - it shows red window frames we believe the ship had in its earlier years. From historian point of view it is not a proof - as both sources are Cornè and one of the sources even does not for sure represent Old Ironsides. But we think in a case like this, where not that much sourves are available the principle of Occam´s Razor must be valid. Or if you take the name "Constitution" on the ships stern: Cornè showed it like this: and in his 1803 side view - he presented the name like that below the ship: William Bass (Author of "Old Ironsides - Superfrigates of the many faces") calls this font "roman" .. And what T.B.E. did by hand to represent this on the model is justs incredible! I will as soon as possible try to recollect and write down that interesting journey and our findings in @uss frolick "stern view" -thread - as we did not only reconstruct the 1797 stern in more details - but also found out more about the 1812 stern worth sharing. What impressed both of us a lot: when we were "theoretically" considering the likelyhood of this or that detail - found a desicion based on pure ration ... and T.B.E. realized it on the model : it always added an even better balance and beauty to the structure. .. as if that new feature really belonged to that position! As if the beauty itself wanted to be a proof. This focus on "function", "likelyhood" and "ratio" leads to a very credible and plausible design - which also has the beauty of a baroque stern. That was a unique experience! Thanks a lot, T.B.E.. Looking forward to our next steps!
  20. TBE found an interesting entry in "History of the Liverpool privateers and letters of marque with an account of the Liverpool slave trade" which was minutes ago available in Internet-Archive .. by a Gomer Williams printed 1897 .. in which a "Captain William Hutchinson, an experienced privateer commander, originally trained in that finest of all nurseries for seamen, the Newcastle colliers, who afterwards became dockmaster at Liverpool" explains how he prepared is privateer for battle: Page 11: and Page 12 to 13: So much to bravery and "gentlemen's attitude" in battle 🙂 .. but hey, we talk about the common man, the sailor, the marine .. And here now the important sentences - proving that hammocks were - at least sometimes - used "in the tops" .. meaning in the fighting tops. That seems to be visible in THIS beautiful painting of the French Ship "Saint-Esprit" .. we see the horizontal hammocks along the shrouds - and we see at least a blue canvas (with white or golden lilies) in the fighting tops side - above the foremasts top shrouds - hammocks possibly stacked behind it. https://en.wikipedia.org/wiki/French_ship_Saint-Esprit#/media/File:Vaisseau_français_le_Saint-Esprit_au_combat_en_1782.jpg Thanks @The Bitter End Haiko, for this finding! There we have at least a verbal prove that hammocks were used in the tops to protect the sailors, marines and sharpshooters from the enemies sharpshooters.
  21. Interesting project - and you said already: "some artistic license" .. Nevertheless: I would close that lowest gun port - as t would be below the water line. There are other issues in your design. But the question is of course: what´s your goal? Your title still leave a lot of room for interpretation of how deep in realism you want to end up? That ship shown here is interesting. A 3-decker for sure. What I noticed: iron stiffeners at the knees and there seem to be strengthening frames on top of the inner planking in the hull. I don´t know enough about the 3-deckers.. but I guess the shape of the hull is not a French design (at least in smaller units they had a less "round" profile). A very flat bottom... Hm.. Could it be HMS Victory? Would of course be the most likely one, right? Worlds most famous 3-decker ...
  22. I was trying to find photos of Antczak´s beautiful model. I remember we talked about it in our PN conversation - and I remember to have seen more photos than the ones I find right now. He did an exceptionel beautiful model, with a lot of very good, very interesting and very likely features for the 1797 concept (as I believe it was - of course nobody knows for sure 🙂 ).. But we noticed then and here again some strange features, which most likely were not existing or differing. The port with the red shutters is the "16th port" below the cat head - which must be that "bridle port" I referred to in one of my previous post. THIS - most likely - wasn´t existing until about 1812, when Bainbridge prepared the third 1812-15 war cruise - just after Hull came back from his defeat of HMS Guerriere. I am searching my documents - but I don´t find the sources for this statement! 😕 Someone able to help me on that? The bridle Port - when added - was smaller than the gun ports following (as there is another later mentioning in one of the logs that the bridle ports were cut to the size of the gun ports - indicating that they were smaller before) - and I don´t find THAT sources either! Need to read my Martin´s "Close up"!! It for sure would have had a lid to be closed - as it was the one most affected by wafes from the bow. .. but I do not believe that it was existing in the early years. If you compare with the Doughty Plan, you will find the very first gun port is just one before the fore mast channels. Below the cat head: no opening in the layout - and most likely not in the later existing ship. I compared the 1819 Ware Deck Plan with the 1849 Pook Gun Deck Plan and you can see the Bridle Port (red marked) in 1819 - being a tiny little bit smaller than the Gun Port #1 (green marked) - while in 1849 the bridle port hat the same size. You also can imagine that any gun there would not have room to run inwards - considering the bow sprit sitting in the center of the deck. No "chase gun" on gun deck level. Here you have a bigger shot of the 1819 Ware Plan - and you see the position and size of the Bridle Port .. In a comparision of Doughty´s plan, Gillmers reconstruction of the 1797 status, Cornè´s 1803 paiting and Pook´s 1849 side view, we can see: in 1803 there seemed to be no Bridle port - although I admit: Cornè´s bow area is a bit awkward .. he seemed to have issues with perspective and dimensions here.. So it is not a proof - but a certain evidence I would give to Cornè. My conclusion: I would rather NOT show an opening below the cat head. In my opinion (until I change it 😁) the first Gun port is the one just forward the fore mast channel.
  23. For landlubbers and newbies in Constitutions early configuration: Be aware that the configuration on spar deck changed between the beginning in 1797 to maybe about 1809/10 for which we have a sketch presumably by Rogders - showing still the orginal and equally between the gun deck ports distributed 7 gun ports in the quarter deck ... Don´t be confused by that boat hanging in the david .. but I think one can see that the quarderdeck gun ports still are in between the gun deck gun ports, right? ... while the later in 1812 the Isaac Hull model already shows the 8 wider carronade spar deck gun ports which are - naturally - not perfectly fitting in between the gun ports. Photo courtesy by Peabody Essex Museum, Salem, MA, USA We know that the ship recieved in 1810(?)/11 the 16 new 32-pounder carronades.. It is very likely that the quarderdeck bulwarks were modified by then .. or maybe later in 1811 in Washington´s Navy Yard, when Isaac Hull took over the command and organized the refit. But that´s not very likely as the ship would have had no spar deck battery while traveling from Boston to Washington without the modification of the too small and too few gun ports. Possible - but not very likely. So just in case someone wonders .. the early configuration differed a bit. And what we see today is still the 8 wider "Carronade" gunports per side along the quarterdeck. Haiko, you sure know that the ship also did not yet have the "16th" "gun port" in the bow - which in fact is a bridle port - not for guns and which - when it was cut by Bainbridge into the hull in - was it end of 1812? - were even a bit smaller than the 15 gun ports on gun deck level. .. just in case 🙂 Interesting maybe: it seems the ship in Rodgers sketch seem to show upper gun lids on gun deck level. Which pretty sure wasn´t the case in 1797 and at least until 1804/05 when Cornè did his beautiful paintings. In those days the ship had detachable gun port lids. But maybe the sketch shows detachable - but mounted and opened - gun port lids. .. We assume them to be detachable at least until 1812 - as the 1812 Hull model again is shown in "battle configuration" without the detachable gun port lids (except the 2 most forward ports - where waves might be an issue even in good weather). Even in 1817 Ware Side view - no fixed gun ports yet ...
  24. I changed my mind: after checking on the Isaac Hull model of 1812 - in which the deck components were done in this special green already - the carriages seem still to be in red. A very dark, dull and faint red (maybe due to the age of that color).. but clearly a red. Still .. its all just guessing.. right? I was checking on other forums - the only discussion about red I found here - click me
  25. Hey TBE , great progress! I fully agree to your point of view: nobody will really see them - maybe with the exception of those close to the waist of the ship were one maybe may see something below in the main hatch .. Hard to tell. If I look at my old 1/96 Revell-model one really has to try hard to see the guns below that boats stored there. Of course your scale is a bit wider .. but .. When I do research for Old Ironsides my very first view is into Tyrone Martins "Close up" - and today I finally found some time to do so for this questions: The only mentioning of something with color are mentioned for the very first years like this: 13 Oct. 1799 -- "blackening the guns" .. Ships log, Jun 1802 -- Gun carriage trucks had iron rims ... Receipt to Jon Taley, 13 Jun 1802, Samuel Brown Papers 14 Sep 1803 -- "..scraping the gun trucks/axlestress and Black leading them..." Ships log Jan 1804 -- painting gun carriage ring botls and leading blocks .. ships log and for Oct. 1804 -- "...repainting Quarterdeck Guns, they are now painted in light yellow in order to correspond with the patinwork of the quarterdeck.." ... Naval Documents relating to Barbary Wars Also later there is often mentioned ".. scrap´d the gun carriages and put black lead on them " .. or ".. blacking .. main deck guns" .. or "balking long guns" .. "blacking carronades" .. But - as far as I understand this - this may not refer to the color of the wooden carriages - than to the barrel itself. And the "blackening with black lead" may refer to graphite - and in that case was not used to protect the surface but to make sure axcle and the seat of the trunnions. Black lead may refer to something like graphite .. as black lead - plumpum nigrum - was the name of that: In Samuel Frederick Gray, A Supplement to the Pharmacopoeia (1821) black lead is described as Plumbum Nigrum - which seems to be the former name of graphite - although the text specifies is at iron and charcoal.. So I guess "black" is not the right color - and the only color mentioned in Martin´s list is the light yellow - to match the 1804 quarterdeck. I did not find any other hint for colors of the carriage. But: there are lists of colors delivered to the ship: Aug 1803 -- Paint pigments in ship's stores included 305# black, 3 cwt white lead, 3 cwt yellow, 50# green ("verdigris"), and 28# red ("vermilion"). [Receipt for John Osborn, 1 Aug 1803, Samuel Brown Papers, MHS.] and later: 11 Jan 1804 -- Received 15 kegs of yellow ochre, 2 of red paint, 7 small ones of black paint, and 50 gallons of black varnish. [Ship's log, DNA.] the August 1803 list indicates that the ship got "3 cwt yellow". A cwt is an old unit - C for the latin word "centrum" for 100. "hundredweight" is in the US the equivalent to 100 pounds. If the description would be meant in british units (I am not sure if the young US did already used their specific units - I remember some very interesting articles about this in Wikipedia!) .. well, if it were british, its even more: 1 cwt in Britain would be 112 lbs . For us that means: the ship had at least 300 lbs yellow, and 28 pounds of red ("vermilion" - which was a bright and very expensive red - not to be mixed with the cheap "swedish red" which is also known as "Red Iron Oxide". The Jan 1804 list talks about 15 kegs of yellow ochre and only 2 of red paint. A "keg" seems to be a barrel of about 30 - 40 pound ..15 kegs would then be about 450 - 600 pounds of yellow ochre. While red is again in a very small amount available. 2 kegs = 30 - 80 pound. BUT: in Martins Oct. 1804 quote we learn that from NOW on the carriages match the quarterdeck in being yellow.. So if we look for those colors - and take that 2 days delivery as an indicator of the likely use of paint for carriages, we might notice: 1. vermillion red is not very likely 2. yellow, or ochre yellow is possible - and was used at least in 1804 - but obvously something else was common before Oct. 1804. 3. green ("verdigris") was the chosen color in 1812 for the features on spar deck - as we can see in the Isaac Hull model. 4. black was available in suffcient manner 5. red - not vermillion - but maybe such a spanish brown - which the following paintings also would "allow" ... This painting by Alonzo Chapelle (done in 1862) shows Stephan Decture - most likely on board of USS United States - although the rounded rail in the background seems to hint on USS Constitution - still the shape does not fit. The gun carriage seems to be black ? I looked for others - but the color is always hard to tell: Isaac Hull patinted in 1815 for his 1812 victory .. is that a black capstan? Baindbridge seems to be beside a yellow, ochre or brownish carronade carriage .. And of course: the painters did most likely not really care for the PERFECT color of those details. They may just been "typical" paintings for them in those days. There still was no "standard" - and most likely the captains may have used whatever was available and cheap. My personal favorite today: black, [Edit with a day of reflection:] changed my mind: a red color seems to be likely - as red ochre was a typical choice - and what´s more interesting: even when Old Irionsides had her greenish bulwarks and deck details: her gun carriages seem to have been red [end edit] or.. if you like - this brownish spanish "red" - at least either a very dark faint color - or an ochre or yellow color - which most likely also is a bit obscure and not very bright and clear. Your spanish brown is a perfect match in this regard .. but I fear: right now we just can guess!
