Everything posted by mtdoramike
Yeah, I suspect that is why the running gear package is setup for a two screw operation. The dummy props woulod have to be for display only because I can see where they we cause a bit of drag if not operational. I know what you mean about space Lou, the model as well as the real deal takes a lot of room to turn, although battle ships weren't as bad as carriers for needing plenty of ocean.
These are some of the extras I received with the kit. The props and prop shafts are for a two screw setup, which is a default setup for most of these battle ship builds. But the actual ship I believe was a 4 screw.
Popeye, you sound like me. I can do anything tomorrow, I can climb Mt. Everest tomorrow, I can become President tomorrow, I can travel around the world tomorrow. Tomorrow, the greatest word ever created. I used that word often when my wife gives me that honey do list. Hopefully for you and Lou, that one day will be tomorrow.
Thanks, inbetween fence building in the backyard and spending the weekend with my grand babies, I was able to spend a little time on the Calypso.
- 58 replies
- Calypso
- Billing Boats
- 58 replies
- Calypso
- Billing Boats
- 58 replies
- Calypso
- Billing Boats
I haven't glued it down yet, awaiting the drive train motors and mounts to come in before I lock it down. It will be easier doing all that stuff before gluing down the main cabin.
- 58 replies
- Calypso
- Billing Boats
This is how my work bench looks when I'm working on a project. I try to keep it clean, which lasts all of about two days.
- 58 replies
- Calypso
- Billing Boats
I was able to spend a little time on the Calypso between honey do's. I'm not going to be stuck on the colors. I will try to stay as true to the actual Calypso as myself will let me. But I just have to add a little extra color.
- 58 replies
- Calypso
- Billing Boats
Yeah, it ain't one of those you can stick under your arm and casually walk into the house with giving your spouse a head tip like saying "what's up?" hahahaha. No, she was the one to actually meet the mailman at the door and yes, the box was well over 4ft in length and weighed about 10lbs. The previous owner included the running hardware with the kit which included all the drive train shafts, two motors, brass props, which came from Dean's marine from across the pond. Unlike most Trumpeter ship kits, this hull is in two pieces. Trumpeter usually makes their hulls one piece. So the box was a tad shorter than some of their kit boxes.
The Big Mo arrived today in perfect condition. The previous owner included some extras with it like some scale sized men and other stuff I haven't had a chance to check out yet. But I put it away for quite a while since I won't start on it until after the Calypso is finished.
Now that's hot right there, I don't care what anyone else says and a bit nerve racking too. Any time I drill into a perfectly good hull I get the nervies.
- 58 replies
- Calypso
- Billing Boats
I took auto body filler to fair in the observation pod on the hull, sanded it smooth then cleared over it with resin.
- 58 replies
- Calypso
- Billing Boats
- 58 replies
- Calypso
- Billing Boats
I actually copied the picture of the Calypso and the Corvette side by side and I'm using it as my computer screen saver/wall paper to give me inspiration.
- 58 replies
- Calypso
- Billing Boats
Those are real beauties, even the dust give them character hahahaha. You really did them proud, absolutely beautiful. If mine turns out half as nice I will be happy.
- 58 replies
- Calypso
- Billing Boats
NO, I love seeing your build. Now I see what you are talking about. I'm used to seeing the entire bottom cabins being removed on most R/C builds which is why I assumed this to be no different. But now that I see your's and I looked through all the plans and deck parts, I see how it is to be done. I'm glad you caught me before I did all that work for nothing.
- 58 replies
- Calypso
- Billing Boats
yes, i would like to see a picture of it if can post or send to my email mtdoramike2@aol.com
- 58 replies
- Calypso
- Billing Boats
But with all builds, there comes some bad with the good and making an R/C model out of a static model always poses extra problems and make no mistake, the Calypso is mainly a static build eventhough they suggest a motor drive train setup diagram. Case in point are the support posts for the roof of the bottom main cabin, which extends to the deck of the ship on ten places on each side of the cabin. This will not work for radio control operation because the main cabin has to be removed to gain access to the interior of the hull for motor adjustments, battery changing switching the model on and off. So this, won't do. I will have to reconfigure this, yes, I could just install them as the plans show and just not secure the bottom of the post to the deck, but they could easily be knocked off. I may end up doing a cantilever type support like a triangle making it terminate into the sides of the cabin instead of the deck. Now if this were going to be a static build and built to represent the Calypso as museum quality or close to it I wouldn't dare think of such a dastardly deed. But since this build is more fuction than form, I'm open to it.
- 58 replies
- Calypso
- Billing Boats
Like with all Billings kits, there are always a lot of plastic parts for detailing where wood would be difficult. Yes, there are also quite a bit of molded plastic parts as well like the boats and helicopter.
- 58 replies
- Calypso
- Billing Boats
I got the glazed portholes in from Modelboatbit in England. It took about 2 weeks to get them, but well worth the effort. They will be going in the observation pod on the nose of the Calypso. The potholes in the kit are unglazed. I needed the ones that had glass for it to work in the water.
- 58 replies
- Calypso
- Billing Boats
With the finished model being 50" inches, shipping would be an issue and quite expensive so I may end up donating to a local VFW or similar. They can always raffle it off or what ever they could do with it. I've donated a Victory model to my local city Library and donated a Montanes tall ship model to our local hospital that held a silent auction and used the proceeds for some new equipment. But, we'll see.
No, no class, no cure and the closest thing to an intervention is my wife's 7 1/2 foot hahahaha.
