Everything posted by mtdoramike
After the first build under your belt, the world is your oyster. You can pick which ever fancies you.
Gregory is right, I usually chunk the dowels from the kits because they are usually warped and go to Hobby Lobby and buy some cheap dowels and make my own.
Where are you located? This could have something to do with the tariffs between the EU and the U.S.
I donated a built Victory to my local Library and also another large ship model to my local Hospital, which holds an auction once a year to raise funds. Now, my question to you is, is your Model Victory in a display case? If not, then most places will not accept it due to possible damage and becoming a giant dust collector. Both my model donations came with display cases.
Harbor Freight 16" variable speed scroll saw
mtdoramike replied to Dr PR's topic in Modeling tools and Workshop Equipment
I used a Harbor freight scroll saw for years, bought it new for $89.00 back then and sold it for $50.00 when I ran across a project that required a deep throat than the smaller Harbor Freight saw. I bought a Craftsman for $150.00. I never had an issue with the harbor Freight saw and never regretted buying it. -
I tell myself that same thing every morning when I crawl out of bed "I'm really still a kid". But then as the day grows older, so do I, to the point I believe that being young and feeling like a kid is a figment of my imagination especially when my mind is saying go and my body is saying hell no.
Why do you think you are writing a thesis? To explain to old goats like us why we do what we do.
Well after building well over 100 models over the past 30 years, I still don't have a clue.
The Model Shipways Bluenose is a great kit, and a pretty easy build especially the planking of the hull. But to me, if you planked the Golden Hind, then you should be able to plank just about any model because planking is the hardest part of any ship model build. So if you can turn out a decent planking job then the sky is the limit for you are far as models to build.
Billing Boats Danmark Fittings Search
mtdoramike replied to Planksforthememories's topic in Wood ship model kits
WOW, good luck with your search, that is a huge fitting package. When I aquired the kit close to 20 years ago, the kit came with the fitting package. Have you tried to contact Billings? I'm sure the fitting package will end up costing you more than the kit is worth. -
Right now, your main goal should be to finish the build because one of these kits can take 1500-2000 hours to finish and that is without a lot of modifications. Good luck and enjoy the process.
Aloha from North Carolina
mtdoramike replied to Charles Roseberry's topic in New member Introductions
Welcome brother. Hope to see some of your builds. -
By the way, I could have just looked at the box and contents and never built it and I would have been happy, beautiful kit.
I know Trumpeter has it's fair share of issues, but it is one of the best companies out there for these types of kits. I understood this when I built the Trumpeter USS Missouri 1/200 and just went with it with a few modifications. Wood is very forgiveable where as plastic is not. You can spend hundreds of dollars on pontos upgrades, but I found most of the offerings in the kit to be satisfactory. My main issue with the Missouri was it being a 4 screw, so I built it with four operational motors and props. But after running it a few times, the outer props will hit every little debris in the water and sheer off the outside props. Now after replacing those props twice at $30.00 each and waiting a month to receive them from China, I regret the 4 screw setup.
